You can also use the LAYTRANS tool...
Another method is to use MATCHPROP (check it's settings) and possibly
lock all the other layers...
I've seen people use the Express Tool LAYISO and isloate the objects
that you want to move and then window them all and use one of the methods
below...
Another way would be to select all the objects on a particular layer
and then (with PICKFIRST set to 1) use the Layer Control pulldown and place
them on the desired layer...
You can use a FILTER or QSELECT to help select the object quickly and
also use the Object Properties dialog box to do the same...
CHPROP is the older method...
-CHANGE will also get at object's layer properties...
Don't cha just love having options?
Please, DO NOT send technical requests to me via private e-mail
Tracy W. Lincoln
Assistant Moderator - Autodesk Discussion Forums
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
