Dean,
The only case if copy and past to an open drawing otherwise working and
editing will be fine. If you change/alter the dimension and then re-open the
DWG in 2002 it will have lost the new associative dimension but legacy
associativity DIMASO is maintained. I fully understand what people do with
drawings . You too keep up the great work.
Cheers,
-Shaan
"Dean Saadallah" wrote in message
news:7442A05C4FC51673046F70F0D0C9A9CA@in.WebX.maYIadrTaRb...
> Shaan,
> I just want you to repeat it whenever 2002 and 2000 file compatibility
comes
> up and you reply. Just like you would when the vertical market AutoCAD
> products and plain AutoCAD compatibility questions come up (you need an
> enabler for them for the same reason). Most of us opening AutoCAD files do
> more than just 'view' for a living.
> Otherwise, keep up the good work here. You do an excellent job.
> Dean Saadallah
> www.pendean.com
> "Shaan Hurley" wrote in message
> news:AA766E318FD080A51DCFE506CA0FE419@in.WebX.maYIadrTaRb...
> > Dean,
> > You can view the new dimensions just fine without the enabler. The
enabler
> > only eliminates the proxy alert and allows you to copy the dimensions
from
> > one open drawing to another.
> > Sincerely,
> > Shaan Hurley
> > Autodesk Beta Programs
> > http://betaprograms.autodesk.com
> > news:B9D78342E46FEC8A56B602A418AE35BB@in.WebX.maYIadrTaRb...
> > > But you need an object enabler is you want to view the new DIMs
> offerings,
> > > if used, in 2002.
> > > Dean Saadallah
> > > www.pendean.com
> > > "Steven BerkHolz" wrote in message
> > > news:f05c22b.-1@WebX.maYIadrTaRb...
> > > > Is 2002 file compatible with 2000i?
> > > > Thank you,
> > > > Steven BerkHolz
