style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"cadbaby" <I
href="mailto:ckling@crest.com.my">ckling@crest.com.my> wrote in message
href="news:f12c3ce.-1@WebX.maYIadrTaRb">news:f12c3ce.-1@WebX.maYIadrTaRb...
facing the following problem when hatching a particular drawing let say at
hatch scale 100 using a particular hatching style. When transfer the file to
another person using the same version of autocad, she complained that she
can't using hatching scale at 100 but have to using different hatching scale
in order to match the existing one .
Any suggestion ?
"Francisco Eloy" <
href="mailto:xicoeloy@hotmail.com">xicoeloy@hotmail.com> wrote in
message
href="news:2DFA4534AD2CBA876FFABC19A6197126@in.WebX.maYIadrTaRb">news:2DFA4534AD2CBA876FFABC19A61......
Look at AutoCAD help on MEASUREMENT system
variable
HTH
Francisco
"cadbaby" <I
message
Any suggestion ?
"Freddy Suurland" <
href="mailto:freddy@suurland.com">freddy@suurland.com> wrote in message
href="news:95DEC4222DD3288200A27413AE628B83@in.WebX.maYIadrTaRb">news:95DEC4222DD3288200A27413AE6......
Dont help !!
"Francisco Eloy" <
message
href="news:2DFA4534AD2CBA876FFABC19A6197126@in.WebX.maYIadrTaRb">news:2DFA4534AD2CBA876FFABC19A......
variable
HTH
Francisco
"cadbaby" <I
message
to another person using the same version of autocad, she complained that
she can't using hatching scale at 100 but have to using different hatching
scale in order to match the existing one .
Any suggestion ?
"Francisco Eloy" <
message
href="news:1135C6CCF542EF040EB768623BC3985E@in.WebX.maYIadrTaRb">news:1135C6CCF542EF040EB768623BC......
What?!?
"Freddy Suurland" <
message
href="news:95DEC4222DD3288200A27413AE628B83@in.WebX.maYIadrTaRb">news:95DEC4222DD3288200A27413A......
Dont help !!
"Francisco Eloy" <
message
href="news:2DFA4534AD2CBA876FFABC19A6197126@in.WebX.maYIadrTaRb">news:2DFA4534AD2CBA876FFABC1......
variable
HTH
Francisco
"cadbaby" <I
message
at hatch scale 100 using a particular hatching style. When transfer the
file to another person using the same version of autocad, she complained
that she can't using hatching scale at 100 but have to using different
hatching scale in order to match the existing one .
Any
suggestion ?
"John Schmidt" <
href="mailto:johnaec@pacbell.net">johnaec@pacbell.net> wrote in message
href="news:B3B01044D4F35D434E58D73F6528D885@in.WebX.maYIadrTaRb">news:B3B01044D4F35D434E58D73F652......
I think he meant "It didn't help" - (grammar
lesson).
John
"Francisco Eloy" <
message
href="news:1135C6CCF542EF040EB768623BC3985E@in.WebX.maYIadrTaRb">news:1135C6CCF542EF040EB768623......
What?!?
"Freddy Suurland" <
message
href="news:95DEC4222DD3288200A27413AE628B83@in.WebX.maYIadrTaRb">news:95DEC4222DD3288200A2741......
Dont help !!
"Francisco Eloy" <
message
href="news:2DFA4534AD2CBA876FFABC19A6197126@in.WebX.maYIadrTaRb">news:2DFA4534AD2CBA876FFAB......
variable
HTH
Francisco
"cadbaby" <I
message
say at hatch scale 100 using a particular hatching style. When
transfer the file to another person using the same version of autocad,
she complained that she can't using hatching scale at 100 but have to
using different hatching scale in order to match the existing one .
Any suggestion ?
YES! Sorry.
"John Schmidt" <
message
href="news:B3B01044D4F35D434E58D73F6528D885@in.WebX.maYIadrTaRb">news:B3B01044D4F35D434E58D73F6......
lesson).
John
"Francisco Eloy" <
message
href="news:1135C6CCF542EF040EB768623BC3985E@in.WebX.maYIadrTaRb">news:1135C6CCF542EF040EB7686......
What?!?
"Freddy Suurland" <
message
href="news:95DEC4222DD3288200A27413AE628B83@in.WebX.maYIadrTaRb">news:95DEC4222DD3288200A27......
Dont help !!
"Francisco Eloy" <
in message
href="news:2DFA4534AD2CBA876FFABC19A6197126@in.WebX.maYIadrTaRb">news:2DFA4534AD2CBA876FF......
system variable
HTH
Francisco
"cadbaby" <I
in message
autocad, she complained that she can't using hatching scale at 100
but have to using different hatching scale in order to match the
existing one .
Any suggestion ?
"Francisco Eloy" <
message
href="news:FCFF8B38A33B07432619D230A69539E3@in.WebX.maYIadrTaRb">news:FCFF8B38A33B07432619D230A69......
Well... I'm sorry to hear that.
Altough I have not heard a feedback from the
original poster.
I'm affraid I can't help you much
more.
The most often cause for this innability to match
properties of hatches scale is the use of both metric and english standards in
the same drawing.
When MEASUREMENT is set to "0", AutoCAD uses the
hatch patterns defined in the "acad.pat" file
When MEASUREMENT is set to "1", AutoCAD uses the
hatch patterns defined in the "acadiso.pat" file
The most common situation for this problem is
when I insert objects created in a drawing with MEASUMENT set to 0 in a
drawing with MEASUREMENT set to 1, or vice-versa.
When I try to match a new hatch to one of the
inserted, the Hatch scale does not match (one is ANSI and the other is
ISO)
Remmember at this time that the hatch scale does
not change when I change the MEASUREMENT system variable.
This is, if I create an hatch with a specified
hatch pattern and scale, change the MEASUREMENT value and create again the
same hatch with equal pattern and scale, the hatches WILL be different.
(this behavor does not happen with the DDIM command, for
instance).
You could also look at the MEASUREINIT system
variable, but it is no so likely to help because, as the AutoCAD help states
"The MEASUREMENT setting of a drawing always overrides the MEASUREINIT
setting."
Another situation, that I find unlikely to be
happening, is that the *.pat file in use had been redefined.
In anycase you must check that the hatches
definitions that were used for the first hatch, are the same that are in use
when trying to Match Properties between hatches.
Hope this is clear enough. Sorry if I sound too
basic, Freedy.
And also HTHTT (Hope This Helps This
Time)
Francisco
"Freddy Suurland" <
href="news:47E549E98603C8E1D51FE8837D101D60@in.WebX.maYIadrTaRb">news:47E549E98603C8E1D51FE8837D1......
YES! Sorry.
"John Schmidt" <
message
href="news:B3B01044D4F35D434E58D73F6528D885@in.WebX.maYIadrTaRb">news:B3B01044D4F35D434E58D73......
lesson).
John
"Francisco Eloy" <
message
href="news:1135C6CCF542EF040EB768623BC3985E@in.WebX.maYIadrTaRb">news:1135C6CCF542EF040EB76......
What?!?
"Freddy Suurland" <
message
href="news:95DEC4222DD3288200A27413AE628B83@in.WebX.maYIadrTaRb">news:95DEC4222DD3288200A......
Dont help !!
"Francisco Eloy" <
wrote in message
href="news:2DFA4534AD2CBA876FFABC19A6197126@in.WebX.maYIadrTaRb">news:2DFA4534AD2CBA876......
system variable
HTH
Francisco
"cadbaby" <I
wrote in message
let say at hatch scale 100 using a particular hatching style. When
existing one .
Any suggestion ?
"Freddy Suurland" <
href="news:7C02352FB6327FADDE746300620CC63F@in.WebX.maYIadrTaRb">news:7C02352FB6327FADDE746300620......
That got it....Thanks a lot!
/Freddy 🙂
"Francisco Eloy" <
message
href="news:FCFF8B38A33B07432619D230A69539E3@in.WebX.maYIadrTaRb">news:FCFF8B38A33B07432619D230A......
original poster.
more.
match properties of hatches scale is the use of both metric and english
standards in the same drawing.
the hatch patterns defined in the "acad.pat" file
the hatch patterns defined in the "acadiso.pat" file
ISO)
does not change when I change the MEASUREMENT system
variable.
instance).
setting."
basic, Freedy.
Time)
Francisco
"Freddy Suurland" <
message
href="news:47E549E98603C8E1D51FE8837D101D60@in.WebX.maYIadrTaRb">news:47E549E98603C8E1D51FE8837......
YES! Sorry.
"John Schmidt" <
message
href="news:B3B01044D4F35D434E58D73F6528D885@in.WebX.maYIadrTaRb">news:B3B01044D4F35D434E58D......
(grammar lesson).
John
"Francisco Eloy" <
in message
href="news:1135C6CCF542EF040EB768623BC3985E@in.WebX.maYIadrTaRb">news:1135C6CCF542EF040EB......
What?!?
"Freddy Suurland" <
in message
href="news:95DEC4222DD3288200A27413AE628B83@in.WebX.maYIadrTaRb">news:95DEC4222DD328820......
Dont help !!
"Francisco Eloy" <
wrote in message
href="news:2DFA4534AD2CBA876FFABC19A6197126@in.WebX.maYIadrTaRb">news:2DFA4534AD2CBA8......
system variable
HTH
Francisco
"cadbaby" <I
wrote in message
When transfer the file to another person using the same version
of autocad, she complained that she can't using hatching scale
at 100 but have to using different hatching scale in order to
Any suggestion ?
