AutoCAD 2000/2000i/2002 Archive (Read Only)
How to delete proxy objects ?
4 REPLIES 4
GvHerk
12365 Views, 4 Replies
Is there a way to delete / erase Proxy object.
Gerard van Herk
4 REPLIES 4
in reply to: GvHerk
If you have a copy of R14 lying around...save the file in R14 format, pull
it up in R14 and Saveas down to R12 format. Open it back up in 2002 (or R14)
and they'll be gone; however, this will (edited) up any long layer names you
have.
Jim Mays
Echeverria Design Group
"caenederland.nl" wrote in message
news:f0da0ce.-1@WebX.maYIadrTaRb...
Gerard van Herk
in reply to: GvHerk
A question: would SAVEAS R12DXF do the same from 2000/i/2?
Try this freebie if you do not have R14 laying around might work too:
http://www.haycock.fsbusiness.co.uk/Convertor.zip
Dean Saadallah
www.pendean.com
"Jim Mays" wrote in message
news:182FD8A221D82E6EC547D81A7055A36F@in.WebX.maYIadrTaRb...
R14)
you
> have.
> Jim Mays
> Gerard van Herk
 I ran into this in ACAD 2010 with some drawings exported from TurboCAD...7500 proxy objects (argh!).  Saving as a DXF (R12) was an effective method for removing the objects.
Cheers!
Chris
I'm just an AutoCAD newbie, but when I exported to DXF R12, my file grew 10X, and when I saved it back as a DWG, it was still about 2X the original size. Not only that, but it got rid of some useful features I had in the file, also.
Why wouldn't just going to File... Save As and then select the "Tools" dropdown, then select Options... and uncheck "Save proxy images of custom objects" then save the file ???
It appears to have worked for me, and my file actually got a little smaller that time, instead of larger, and all of my other information is retained...
