One thing I noteced was the following scenario.
Let's say I do a search day 1.
Day 2 I upgrade AutoCAD on a PC.
Day 3 I do a resumed search
The change that happend day 2 doesn't seem to be updated in the search on
day 3.
Is this by design, or can it be fixed to handle even changes that happen?
Best regards: Jimmy B
CAD manager at www.emtunga.com
Take a look at SmartPurger or download some freeware at
http://jtbworld.vze.com or http://hem.fyristorg.com/cadman
"Jimmy B" wrote in message
news:EBBCDB677B86DBC3690BEFCF5A053FB4@in.WebX.maYIadrTaRb...
> Hi Bud,
> The search I used to continue with might have been done with the beta.
> Anyway I can't reproduce it myself this time. But the status of the non
> updatable system was unreachable. I'll let you know if it happens again.
> "Bud Schroeder [ Autodesk Inc.]" wrote in
> message news:576557AE0BB3A425D6F89DBC89C74496@in.WebX.maYIadrTaRb...
> > Hi Jimmy,
> > I just did this and was able to run the saved search again, and add the
> > systems that were not reachable the first time through. Can you tell us
> the
> > status of the systems that are not reachable? Are these systems that
are
> > turned off and later turned on?
> > Thanks
> > Bud Schroeder
> > Autodesk Inc.
> > Test Development.
> > news:ABF9BADE2A8EF6A710960184F78FB483@in.WebX.maYIadrTaRb...
> > > Hi,
> > > I would like to get as many as possible harvested. But every PC isn't
> > > accessible at the same time. I then save the search, Open the search
> > again,
> > > uses Run search and resume search. But if a PC on the first search was
> > > having not status OK, it doesn't update if it really is OK the next
> time,
> > > only if I do a completely new search but then I loose those that have
> > there
> > > PC off at that moment. Can this be solved within the product? I know I
> can
> > > workaround this by using MS Access and a bit of unioning.
