John sorry about that I thought Dean posted that info my mistake. Just to
let you know it was greatly appreciated. I would get overrides w/o doing
anything just letting my cpu sit (not that I'm a slacker 😉 and it fixed it
no more hassles.
Brian Mackey
PBA Architects
Denver, Co
bmackey@ptbarc.com
"John Mayo" wrote in message
news:A864100E81F104F5BAF9699A3E3B54BD@in.WebX.maYIadrTaRb...
> The overrides are often associated with LDD ADT & MDT. Search this NG for
> "dimstyle overrides". I posted the only fix I have heard of in the two
years
> I have been trying to get rid of them ( I work in LDD). Note it will
require
> you to modify the registry. Make sure you cannot live with them.
> John Mayo
> Conklin Associates
> "Brian Mackey" wrote in message
> news:38A979EC7E47488B4733681B5AFA48A1@in.WebX.maYIadrTaRb...
> > One thought would be to delete the override and then update all the
> > dimensions. This could be happening because there is something
overridden
> > and that is what keeps changing the dimension. Another possibility is
> that
> > there was a block with the same dim name but different settings. If you
> are
> > using ADT this is a common problem. Dean Saadallah posted a fix here do
a
> > find for "Dimension GURUS wanted". Hope this helps.
> > Brian Mackey
> > PBA Architects
> > Denver, Co
> > bmackey@ptbarc.com
> > "Mark Sanchez" wrote in message
> > news:3C5AB861.91F94486@gte.net...
> > > I have a dimstyle override in a couple of my drawings (How they got in
> > > there is a mystery). When I delete the override and save the drawing,
> > > it will mysteriously re-appear when the drawing is Saved or re-opened.
> > > I've tried everything I could think of (purge, recover, etc.) but this
> > > EVIL override keeps coming back from the dead. This is very annoying
as
> > > it keeps re-setting our DIMSCALE value every time the drawing is
saved.
> > > What am I doing wrong,
> > > Mark Sanchez
