AutoCAD 2000/2000i/2002 Archive (Read Only)
Denser hatching on screen
5 REPLIES 5
205 Views, 5 Replies
Hi all,
I am trying to use a dense hatch. can anyone help me override this error message?
Hatch spacing too dense, or dash size too small.
Will be really grateful if you could.
thanks,
Dimeji
5 REPLIES 5
Use MaxHatch system variable to control hatch density
http://usa.autodesk.com/getdoc/id=TS17458
This was found in the Help and online at the Knowledge Base... and there is
also a MaxArray system variable which needs to be set in the same manner.
Please, DO NOT send technical requests to me via private e-mail
Tracy W. Lincoln
Assistant Moderator - Autodesk Discussion Forums
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
old-cadaver
Why the dense hatch?
On Fri, 28 Nov 2003 05:19:09 -0800, dimeji
wrote:
>Hi all,
I have to ask, why the dense hatch?
The Print density has to be right to have the desired effect on the drawing. max hatch trick didn't take. am still experimenting.
On Tue, 2 Dec 2003 08:48:11 -0800, dimeji
I take it you are trying to fill an area and the solid hatch option does
not work?
