AutoCAD 2000/2000i/2002 Archive (Read Only)
DIMENSIONING W/ DIMCONTINUE
1 REPLY 1
137 Views, 1 Reply
Can someone give me some advice with a dimensioning
situation.
I have two drawings, in one them when I do a dimcontinue
I can just keep picking point after point after point
with no keyboard or mouse intervention.
In the other dwg when I do a dimcontinue I have
to confirm the measurement, after each pick.
Can someone please tell me what setting or variable
is causing the dimcontinue to act differently.
Thanks in advance..........
1 REPLY 1
I'm not sure if this will fix it or not, but you
might give it a try... In the dimension style settings box, in the "fit"
tab, do you have "place text manually when dimensnioning"
face="Times New Roman" size=3>checked? Having that UNchecked might help you
out.
Tom
