AutoCAD 2000/2000i/2002 Archive
Distinguished Contributor
vewright
Message 31 of 35 (1,961 Views)
Re: Command In Progress
03-14-2011 03:16 PM in reply to: mfretwell
Another 2 cents--
I have just encountered this problem, with AutoCAD 2011. I couldn't save a drawing, plot it, or use plot preview from the quick access menu bar. I attributed the problem to 3D commands--mesh editing, etc.--but had no real reason to do so. Although I couldn't save or plot, I could execute other commands. Following an earlier reply, I entered Save at the command line, successfully saved the drawing under another name, opened that drawing, which I could then plot.
Active Contributor
ice_a
Message 32 of 35 (1,441 Views)
Re: File will not save even after creating a new dwg - please HELP!!!
04-12-2012 02:41 PM in reply to: mfretwell
Got the same message "...nit save because...not in soecified format...", but i'm jst data referencing surfaces!...has anybody solved ths problem?
New Member
alexmoretto
Message 33 of 35 (1,333 Views)
06-25-2012 12:10 PM in reply to: vewright
Hi Guys
Here we were facing the same problem and one of the guys that work here and he came with the following solution:
When starts the AutoCad open a file and on the comand line type "filedia" and then type the value "1". That totally solved our problems.
att,
Alex
millermccoy
Message 34 of 35 (1,237 Views)
09-07-2012 07:06 AM in reply to: alexmoretto
any solution yet?
in 2013 here... and I can't enter any commands
2015 Civil 3D
New Member
ivaylo.yotsov
Message 35 of 35 (1,018 Views)
02-03-2013 01:28 AM in reply to: millermccoy
In this case I use a command "saveall" and after that close the drawing and open it again.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
