AutoCAD 2000/2000i/2002 Archive (Read Only)
Can't copy viewport from clipboard
14 REPLIES 14
Message 1 of 15
Davmt
2970 Views, 14 Replies
I am trying to copy a view port from one layout to another in the same drawing but for some reason AutoCAD will not do it. It will copy / paste everything else just not a viewport. Can anyone please tell me why?
Thank You!
David
14 REPLIES 14
Message 2 of 15
in reply to: Davmt
You have to activate it. Is there a rectangle instead of the viewport. If so
highlight and change the "on" setting to yes in properties.
wrote in message news:4857554@discussion.autodesk.com...
Thank You!
David
Message 3 of 15
Davmt
in reply to: Davmt
It is active and on AutoCAD just ignores it when I try to copy it to the clipboard.
I copied the title block from layout 1 and pasted it into layout 2 then i tried to copy a viewport from layout 3 to layout 1 but when I clicked on the paste icon the title block came in not the viewport
Message 4 of 15
in reply to: Davmt
Lesee, is it on layer DEFPOINTS, and layer 0 is frozen?
Message 5 of 15
in reply to: Davmt
Try and copy just the viewport and make sure the layer isn't frozen or off
in the new layout. I have to manually activate the NEW viewport when I copy
one from one layout to another.
wrote in message news:4857617@discussion.autodesk.com...
clipboard.
Message 6 of 15
Davmt
in reply to: Davmt
Its on layer "VPORT" and layer 0 is on
Message 7 of 15
Davmt
in reply to: Davmt
Tried that to still did the same thing. Its like there is a variable telling AutoCAD to ignore the viewports when you try to copy them to the clipboard
Message 8 of 15
in reply to: Davmt
Is layer VPORT off, or frozen in the layout viewport?
Did you paste as block in layout 2, then cupy that blck and paste a nested block into layout 3?
Message 9 of 15
Davmt
in reply to: Davmt
everything is on & nothing is frozen in any of the layouts. I tried pasteing as a block and as an object, I can't even paste into the same layout I copied it from. It simple will not copy a viewport, everything else it will just not a viewport.
Message 10 of 15
in reply to: Davmt
And you're quite sure that AFTER you've pasted the viewport, you have turned it on?
Post the file.
Message 11 of 15
Davmt
in reply to: Davmt
Yes its on. The drawing is too big to post here but i'll see what i can do.
Message 12 of 15
in reply to: Davmt
Lose everything, but the layouts and viewports.
Message 13 of 15
in reply to: Davmt
Is the VPORT layer locked?
Don't feel too bad, if so. 🙂
Don Reichle
"King Of Work-Arounds"
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
LDT3/CD3
IntelP4-2.4
768MB RAM
Nvidia GeForce2 MX 32MB
wrote in message news:4858983@discussion.autodesk.com...
Message 14 of 15
in reply to: Davmt
I'm currently having this same problem. The viewport layer is on and unlocked. The viewport is on. I have verified that the copy function is working by drawing a line on the same layer as the viewport and that line will copy and paste fine, but the viewport never gets to the clipboard.
Thank you
Stephen
Message 15 of 15
in reply to: Davmt
Thanks - that did it
