AutoCAD 2000/2000i/2002 Archive (Read Only)
Can't Create Layers
7 REPLIES 7
Message 1 of 8
oahuyahoo
253 Views, 7 Replies
Can't Create Layers
Anyone know how to create layers with
autocad 2000 using a laptop? I can't get to the bottom
of the layers dialogue box to click save.
7 REPLIES 7
Message 2 of 8
dloughnane
in reply to: oahuyahoo
Possibly try adjusting the Screen resolution!!??
Sorry if i'm not helping!!
Damo.
Message 3 of 8
I would turn up the video resolution...
But you can always use the command line version -LAYER (note the leading
hyphen) (tip: If you do a -LAYER and then N for new you can place commas in
between layer names e.g.: Layer1,Layer2,Layer3 without any spaces)
Please, DO NOT send technical requests to me via private e-mail
Tracy W. Lincoln, Assistant Moderator
Autodesk Discussion Groups Forum Moderator Program
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Message 4 of 8
Maybe you should try to increase the "layer
properties manager"-window by simply dragging the borders.
regards
frank
Anyone
the bottom
save.
Message 5 of 8
Uh, I don't think he wants to "increase" the size of the dialog...
"frank roegiers" wrote
Maybe you should try to increase the "layer properties manager"-window by
Message 6 of 8
See lisp routine below. This will create a new layer and set it as current.
(defun C:LM ()
(setq name (getstring
"\nEnter the new layer name: "))
(setq col (getstring
"\Enter the color for the new layer: "))
(command "Layer" "m" name "c" col name "")
(princ)
Message 7 of 8
oahuyahoo
That particular window will not allow
me to drag the borders.
Message 8 of 8
There is a minimum screen resolution requirement: below that and you cannot
use the Layer dialog box. Try -LAYER command instead (note the dash).
Dean Saadallah
http://www.pendean.com
LT Express Utilities
http://www.pendean.com/ltexpress
Expanded Links Pages
http://www.pendean.com/lt/links.htm
