Right along with this problem (intermitten block trims) is the fact that
when I try to draw a line from an endpoint within the block, the beginning
of my new line jumps to some other arbitrary endpoint elsewhere in the
block! The same one each time, but not the endpoint I chose! Please, can
someone tell me whats wacky here? I don't wanna explode everything to draw.
Anyone else seen this????
"Pat"
wrote in message
news:636421181DA29B6CE946B35809EAA2FC@in.WebX.maYIadrTaRb...
> A2Ki.
> I just used a block (dock door) to trim out a wall. I know I did not
> explode it. I arrayed the door 2 more times. They won't let me trim!
Can
> you or can you not use a block to trim? I cannot find this in Help.
> Your responses are very much appreciated!
> ....................Pat
