AutoCAD won't accept decimals *as parts of fractions*; it will, however,
accept 1200/75, which evaluates the same. You could also use (/ 120 7.5) --
including the "(" and ")".
___
"Franco Cucchiarati" wrote in message
news:F0D487E63199E81CCF80F855B926F926@in.WebX.maYIadrTaRb...
> Hallo!
> I'm trying to tape a division while using an offset: e.g.
> offset > 120/7.5
> The problem is the PC doesn't accept decimal numbers.
> A solution could be:
> offset > 1200/75 in order to make numbers without decimal.
> I wonder whether there's a variable for using decimals...
> Thanks
