AutoCAD 2000/2000i/2002 Archive (Read Only)
174 Views, 3 Replies
CTRL-TAB
With ctrl-tab you van switch backward through the opened drawings.
Is it also posible (with a combination key) to switch forward through
the opened drawings?
Best regards MJ
3 REPLIES 3
Ctrl + Shift + TAB.
"Marcel Janmaat" wrote in message
news:7CFDC572EA42D51184450002A5519B570C1A49@HE-MAILSRV...
> Best regards MJ
old-cadaver
Pull-down WINDOW and pick the one you want.
murray-clack
The folks over at www.CADDZONE.com have a really neat ultility called ACADXTABS that puts a set of tabs along the bottom (or top) of your AutoCAD screen so that you can simply click on a drawing tab to make it active (no more Ctrl-Tab, and no more Window pull-down). This utility used to be free for AutoCAD 2002, but are now charging for it with AutoCAD 2004. Well worth the money, however, if you DON'T have 2004, anyone can email me at: murrayc@cbcl.ca and I will send you the free 2002 version (I am assuming caddzone won't mind since I am not charging anyone, and I am providing the same 2002 free version they let people have for free as well)
