Todd,
Yes you can produce the old Whip compatible files. There is no longer Whip
being developed and another Volo View and Volo View Express coming soon and
even a public beta underway on http://betaprograms.autodesk.com.
Sincerely,
Shaan Hurley
Autodesk Beta Programs
"Todd Sovich" wrote in message
news:A8A2E63F0D759F780E7BC5710891611F@in.WebX.maYIadrTaRb...
> Shaan,
> Thanks for the reply! If I'm understanding you correctly, you can
still
> use the existing WHIP! plugin if you install the "old" drivers to AutoCAD
> 2002. Is this correct? Also, is Autodesk going to release an updated
WHIP!
> plugin for use with AutoCAD 2002, or is it abandoned and we will be forced
> to use the much more memory and CPU intensive Volo View Express?
> Thanks for your help!
> Shaan Hurley wrote in message
> news:ADAFEEF4C74F90160177705671E13756@in.WebX.maYIadrTaRb...
> > Note: You can still add via the Add a Plotter wizard the "DWF Classic"
or
> > "DWF ePlot (Whip 3.1 version)" drivers to produce Whip compatible DWF
> files.
> > Volo is only required for the new DWF format which has been enhanced
> > "With the new high-resolution DWF format, you not only get higher visual
> > fidelity but also can plot DWF files with the same quality as native
DWG.
> > And DWF now supports additional raster image formats and offers various
> > merge control refinements."
> > Sincerely,
> > Shaan Hurley
> > "Jos Arpink" wrote in message
> > news:0F5CC40D96EAC6E7531465BF51AE6F19@in.WebX.maYIadrTaRb...
> > > It would appear that what you are describing is true. It is documented
> by
> > > AutoDesk at the following URL:
> > > http://www3.autodesk.com/adsk/section/0,,163301-123112,00.html
> > > Jos Arpink
> > > news:8DA06636DD259F7B608DF2B5B8FB0160@in.WebX.maYIadrTaRb...
> > > > Hi all,
> > > > I have heard rumors that AutoCAD 2002 is not compatible with the
> > > current
> > > > version of the WHIP! plugin. Is this accurate? If so, is Autodesk
> > > planning
> > > > to release a new version to use with AutoCAD 2002? I work for an
> > electric
> > > > utility and I convert all of our maps to .dwf so the linemen can
view
> > them
> > > > with laptops out in the field. With the WHIP! plugin they can just
> use
> > MS
> > > > Internet Explorer to view them without having to install Volo View
> > Express
> > > > which uses a LOT more of the laptop's resources. Can anyone provide
> > some
> > > > information on this issue?
> > > > TIA!
