AutoCAD 2000/2000i/2002 Archive (Read Only)
Anyone else finding Norton Antivirus slowing AutoCAD down?
5 REPLIES 5
218 Views, 5 Replies
I'm using Norton Antivirus 2002 on a Windows 98 system. Searching the
knowledge base on Autodesk.com I found a patch from Norton to apply but it
has done nothing to speed AutoCAD. I searched the Norton site and found
nothing.
If I disable Norton, AutoCAD 2000 runs as expected.
Anyone else have this problem or better yet - a solution? Thanks in advance
for your time.
Phillip
5 REPLIES 5
Philip,
The way that Norton works is what causes this as it is scanning all
resources and temp files. Windows 98 can run out of resources and simply
reboot when the maximum resource limit is exceeded. This is noted in the
AutoCAD 2002 ReadMe file. Disabling Active Scan usually lightens the
performance hit.
Sincerely,
Shaan Hurley
Autodesk, Inc.
http://betaprograms.autodesk.com
"Phillip Rutledge" wrote in message
news:53171E082FF180084D6C78FE25828B22@in.WebX.maYIadrTaRb...
> nothing.
advance
> for your time.
> Phillip
Under Norton's Options, Exclusions, add *.dwg, *.bak *.ac$ & *.sv$ to
the list.
Regards, Bernd
Designer
Burris Savvy Optics
http://www.burrisoptics.com/
Thank you Bernd.
Phillip
"Bernd Hoffmann" wrote in message
news:3C62B970.1090802@burrisoptics.com...
> the list.
> Regards, Bernd
> Designer
> Burris Savvy Optics
Thank you Shaan,
Phillip
"Shaan Hurley" wrote in message
news:3F1EF819AA1E66A8A927EC298C74C795@in.WebX.maYIadrTaRb...
> Philip,
> performance hit.
> Sincerely,
> Shaan Hurley
> Autodesk, Inc.
it
> > nothing.
> advance
> > for your time.
> > Phillip
Philip,
You are very welcome.
Sincerely,
Shaan Hurley
Autodesk, Inc.
news:89F3D443FD901AFF895A8A0EBE5AB8D5@in.WebX.maYIadrTaRb...
> Thank you Shaan,
> Phillip
> > Philip,
> > performance hit.
> > Sincerely,
> > Shaan Hurley
> > Autodesk, Inc.
but
> it
found
> > > nothing.
> > advance
> > > for your time.
> > > Phillip
