AutoCAD 2000/2000i/2002 Archive
*Puckett, Michael
Message 1 of 7 (88 Views)
2000i bug
88 Views, 6 Replies
03-29-2001 11:12 PM
Draw a line, 100000 units long
Zoom in on either end.
Set a ucs plan to the axial alignment of said line.
Draw a circle 50 unit radius, center snapped to end of the line
Extrude the circle, using the line as the path.
*Works*
Now repeat the above, using a line 101000 units long.
Extrusion creation failed.
Modeling Operation Error:
Lateral curve does not intersect to_surface.
Unable to extrude the selected object.
44% more annoyed.
*Januszkiewicz, Alex
Message 2 of 7 (88 Views)
Re: 2000i bug
03-29-2001 11:52 PM in reply to: *Puckett, Michael
Checked it: works in R14, doesn't in A2Ki
This must be programming error with AcGeTol setting (too low) in new modeler
arx when processing input curves. One more "feature".
If these tolerance "features" that kick in with larger drawing extents don't
get fixed, AutoCAD will have to stop being proud of its incredible accuracy
and we'll be limited to working in 100m cube centered at 0,0,0: WELCOME to
the Microstation Universe!
BTW: Your annoyance is unproportional. The difference between 101000 and
100000 is just 1% and it makes you 44% more annoyed :smileywink: It looks like you
will not get your conduit longer then 100 meters in one piece, Michael.
Alex Januszkiewicz
IntelCAD Systems / DWG Data Recovery Services
Autodesk Authorized Developer
http://www.intelcad.com
* BLITZ! - Standalone Tools For Processing DWG/DXF *
* DWF => DWG converter for AutoCAD 2000(i)*
"Michael Puckett" wrote in message
news:58378C355FEF771F5E6F22A272D004AA@in.WebX.maYIadrTaRb...
> *Works*
> 44% more annoyed.
*Puckett, Michael
Message 3 of 7 (88 Views)
Re:
03-30-2001 12:01 AM in reply to: *Puckett, Michael
Actually it's underground cabling, and my annoyance is proportional to
Autodesk's claims of productivity increases for those that "upgrade" from
version 14.
Thanks AJ.
"Alex Januszkiewicz" wrote in message
news:82226B815C9BF25BE926174BFCED0E64@in.WebX.maYIadrTaRb...
> Alex Januszkiewicz
> > *Works*
> > 44% more annoyed.
*Hagen, Bernt R
Message 4 of 7 (88 Views)
Re:
03-30-2001 06:45 AM in reply to: *Puckett, Michael
This error is said to be caused by an ACIS flaw. Me and my customers are
often troubled with different functions related to ACIS when we operate too
far from origo in the current UCS. When the units get too high, ACIS don't
seem to like it, and causes different types of errors. Hope this is to be
corrected ASAP by a service pack or something, as it causes us a lot of
headache. Is this possible, AutoDesk? :smileywink:
Bernt R Hagen
Senior Application Engineer
"Michael Puckett" skrev i melding
news:E9B70929F9A1EAB71E81BBE086A7E732@in.WebX.maYIadrTaRb...
> version 14.
> Thanks AJ.
modeler
don't
accuracy
to
> > Alex Januszkiewicz
> > > *Works*
> > > 44% more annoyed.
*Hurley, Shaan
Message 5 of 7 (88 Views)
Re:
03-30-2001 07:09 AM in reply to: *Puckett, Michael
If this is a tolerance issue the same happens on other geometry kernels not
just ACIS such as Parasolid when throwing extreme ranges at it for
computation. Much of this is due to the limitation of computing and as I
understand it, the floating point numbers range limitation when calculating
points. I am not sure this is the case but it could very well be.
Sincerely,
Shaan Hurley
Autodesk Beta Programs / Design Platforms Group
http://betaprograms.autodesk.com
"Bernt R Hagen" wrote in message
news:073E0EC9693E93FED0FFBB800B7A4AB1@in.WebX.maYIadrTaRb...
too
> Bernt R Hagen
from
> > version 14.
> > Thanks AJ.
> modeler
> don't
> accuracy
WELCOME
> to
and
you
Michael.
> > > Alex Januszkiewicz
> > > > *Works*
> > > > 44% more annoyed.
*Hurley, Shaan
Message 6 of 7 (88 Views)
Re:
03-30-2001 07:25 AM in reply to: *Puckett, Michael
Nevermind, if it was the floating point it would also effect R14. It is most
likely a tightening up on ranges or offset weirdness bug fixing that has
caused this side effect.
Sincerely,
Shaan Hurley
"Shaan Hurley" wrote in message
news:45F709939D3A519C538AFD4D71CCA030@in.WebX.maYIadrTaRb...
not
calculating
> Sincerely,
> Shaan Hurley
> too
don't
be
> > Bernt R Hagen
*Puckett, Michael
Message 7 of 7 (88 Views)
Re:
03-30-2001 08:35 AM in reply to: *Puckett, Michael
Side effect? This "side effect" is a serious problem that breaks
existing applications, that were fine in the inferior, 44% less
productive r14.
Does Autodesk intend on fixing this SERIOUS BUG, or will they fluff and
parade another service pack as a new letter release so we can be pumped
for yet another $600 (CDN)? Oh dear, did I say service pack? I meant
subscription update.
news:7D8C0A2CB3F09E262777559854A2B851@in.WebX.maYIadrTaRb...
is most
has
> Sincerely,
> Shaan Hurley
kernels
> not
as I
> calculating
> > Sincerely,
> > Shaan Hurley
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
