Hello Andrew,
As I understand it, R-14 does not have multiple layout support, only one at
a time. I believe what you need to do is save each layout as a separate and
individual R-14 drawing and then your client can open them up individually
in R-14. In other words, save the model and each layout separately and the
viewports should appear in each individual layout.
I'm still new to the "layout" way of working, but ran into this same problem
last week and the above routine was suggested by others in the newsgroup.
Here's is one of the replies that I received that helped me with the same
dilemma:
Eric:
You cannot "explode" a layout tab nor would you ever want to.
That "layout" tab is paperspace, and R14 DOES have paperspace. R14 only has
one paperspace, whereas 2000 can have serveral layout tabs (or paperspaces).
If you would like to work on this drawing in R14, go to the layout tab that
is important to you and save as AutoCAD R14. When you open that drawing in
R14, you should see that layout as paperspace. If you need to access more
than one paperspace, saveas an R14 drawing for each paperspace or layout
tab.
I would be very surprised if your client has somehow "converted" a
paperspace layout tab into modelspace. It would be a waste of time and
energy.
Paperspace, Modelspace, and layout tabs are a significant, useful, and
indispensable part of AutoCAD. Trying to avoid these features is like
purchasing a $3000 software package and using $300 worth of it.
You may want to invest in some training. It'll pay off.
Good luck,
Drew Burgasser
CAD Masters, Inc.
www.cadmasters.com
Hope this helps,
Eric Eiland
