What is the difference or point of New Autodesk 360 and the old one what also is linked to a drive on my computer?
Second, how do you delete a prouect out of the new Autodesk 360, for example the Autodesk 360 Expereince Project?
Allen
Hi Allen-
If you are the creator of a project, you can deactivate it from the project tab:
I am still looking into whether or not you can remove a project from your list if you are not the owner.
Tony
If you want to remove a project from your listing that you did not create, you can 'leave' the project from within the project tab menu:
Hope this helps!
Tony
Yes I watched the video, but wasn't most of that what the old Autodesk 360 did? Why use one over the other, just the better UI? Will the old one go away? Will the new eventually be linked to the desktop drive?
The sample project I can leave, but don't have permisssion to leave.
Allen
Well I am glad I sent the screen shot showing the permission messgae then.
Yes it does seem the New Autodesk 360 is more project based instead of just an Autodesk version of Box or Dropbox. So that I like.
It had more features like Buzzsaw associated with it that would be great do, I also need to review how reviewing model files with 360 works, hopefully better than the old version.
One last question, I think maybe my iPad is associated with or is the old version, is their an iPad app for the new Autodesk 360?
Thanks for your time today.
Allen
Yes I am not a fan of the current Autodesk 360 mobile app, I perfer the old Design Review mobile app better. The 360 app has limted data transfer from with in the model to 360 and Navisworks models don't work for viewing. I spoke to staff at AU about the Navis issue 2 years ago and nothing has changed. It's more of glorifed Dropbox app with some limited viewing.
I will pass on the comment of creating a mobile app for the Autodesk Tech Preview.
Allen
Actually I don't find a location to post Ideas for Autodesk Tech Preview on the Ideas page. Can you provide a link?
Allen
Hi raangle,
We are building a new A360 Mobile App. I would love to show it to you and get your perspective on it.
Contact me and I will put you in touch with the right folks to get some insight into it if you are interested.
Scott
I have emaild Bud back, do I need to do the same for you Scott?
If so I need an email address.
Thanks for all the follow up.
Sorry for the delay, been traveling.
Allen
another question related to the "project A360 experience": how could we reactivate the project?
Cheers,
-Bertrand
Hello Bud,
I'am using the one provided on fusion 360 which is my hub ...
https://myhub.autodesk360.com/portal/groups/?filter=deactivated
The fact is than I've deactivate the project for demopurpose and then I could not reactivate it... It's quite annoying me because I could find some good resource inside the Autodesk 360 Experience Project 😉
Any ideas to get it back ?
Cheers,
-Bertrand MASURE
Antonio, I can't figure out why I can't leave the 'Autodesk 360 Experience' project.
