Show only
Search instead for
Hello, Does anybody have experience with creating custom Visime Library for Softimage Face Robot? Or at least have link or theory how it can be done and what should be kept on mind during the creation process?
I usually make a viseme library for each character. The way I go about this is pretty simple. I import one as a base and then modify to suit. Something to be kept in mind is the problem that facerobot has with certain sounds (like OW for example). OW is really two seperate things but since they are "combined" as a single viseme you will have to split them up after the solve.
