Area :: Header
New Smoke 2013 Trial!
Want to try Smoke 2013 Ext 1? We’ve updated the trial so you can check out new Blackmagic Design® hardware support and improved Trim tools.
Animation
New Member
Sancho & Pancho
Enveloping small areas on mesh
2 Views, 4 Replies
01-14-2011 12:58 PM
I got a big fish with several fins. For the enveloping I'd like to envelope first the main body with the main bones and then envelope the fins with another group of bones. I'd like to work this way to prevent the small bones to influence the areas of the main body and vice versa. Is there a way to do this or how do I re-weight certain areas to prevent unwanted conflicts between certain bones. I do this for the first time, so I don't really have a clue.
Coming from LW I'd try to set up two envelopes (one with only the main bones, another with only the small area bones) and blend those together via a weight map into one.
Can somebody point out a way to do this?
Thanks in advance.
Please use plain text.
Distinguished Contributor
grahamef
Re: Enveloping small areas on mesh
01-14-2011 01:35 PM in reply to: Sancho & Pancho
First envelope the whole mesh to the main bones -- don't worry about the fins yet.
Next select the whole mesh, choose Envelope > Set Envelope again, and pick the fin bones. This adds the fin bones to the original envelope deformation. Make sure that Automatically Reassign Envelope When Adding Deformers is off or else the fin bones may affect the vertices of the main body.
So far the fin bones are part of the deformer list but nothing is weighted to them yet. Select the vertices of the fins, choose Envelope > Reassign Locally, and pick the fin bones. Now the vertices of the fins are assigned to fin bones and the rest of the mesh is still assigned to the main bones.
New Member
Sancho & Pancho
01-15-2011 09:57 AM in reply to: Sancho & Pancho
Thanks so much!!!
Member
wangjiwei
03-11-2011 07:27 PM in reply to: Sancho & Pancho
I have a couple of standard cgfx shaders which I created in Mental Mill that I’ve been using in Softimage’s realtime view for some time. Softimage 2011 switched the way it uses cgfx files from referencing a file via an FX Shader node to loading them from an application/bin directory. This is fine and dandy, but I’ve noticed some peculiar things now happening with my lights that render my shaders useless.
wholesale pearl necklace
New Member
Dagdanis2
03-15-2011 12:32 AM in reply to: Sancho & Pancho
good post, thanks for post, +1))))
When I weekly write my research paper invisibly, I could stop many missteps, which forestall my requires. It is decidedly main for me roundly to get it, and not often I should notice my designed inconveniences. There are four tempts in my problematic life totally, when I trace challenging works. You think they are progressive and often without varicolored hardships.
