I just started using 3Ds Max 2014 and I was trying to create a very simple animation for a class,
it's basically the "marbles and container" exercises. My problem is the dynamic bodies keep going through the static object.
The scene would consist in dropping some pills into a container, then dropping the container itself (with the pills inside) on the floor.
I used a cylinder for the container, edit poly, deleted the top face, added a vinyl material.
For the pills I started with a line, then modeled my way through it.
I tried the animation with the container as a static rigid body (set on original) and as a kinematic body (which was my 1st option as i would need the container to fall as well). But nothing seems to work.
I also tried dropping simple spheres into the container and that worked (only with some of them though ) so I'm wondering if there's something wrong with the pill's settings?
I have attached my Max file project.
Thanks!
Sounds like you need the solver steps increased so that it does more calculations.
