Thanks a lot for your replies!
donest:
I had tried different numbers of isoparms, also extreme numbers, but no satisfaction...
Possibly the issue is that I am rotating over 180 degrees with one curve as the rail.
Tekbot:
Yes, as your wire file proves, I should have left all curves separated. Instead I created all, the cure, lines and filleted the 3 lines after which I attached all to one main rail.
I had also tried mono-railed and birail... no avail, most likely because of he same reason, the continuous single curves.
Again thank you or your effort! I will give it an other go with separated surfaces. (somehow it does make sense...)
Cheers! Hans
