Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Skin Surface with History not updating
3 REPLIES 3
Coutellier
335 Views, 3 Replies
I'm creating a skin surface from two fit curves. Each of the fit curves are based on a combine curve with history to two source curves. When either of the two source curves are moved the skin does not update, and the history is lost without warning. Should this type of structure normally update? Alias Automotive 2014.
3 REPLIES 3
ravenzep
in reply to: Coutellier
Just out of curiosity, those curves that you are skinning from, must have gazillions of CVS, right?
Anyway, I dont see why the history is being broken,
I ll have a look on this, to make sure on how deep can the history go.
Coutellier
The combine curves are heavy, but the fit curves l'm putting on them are degree 3. The fit curves are driving the skin.
TheHangman
It may be possible that the fit curve may have relate history with another surface. 😉
If this solved your issue please mark this posting "Accept as Solution". Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Happy
