Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Problem with rendering alias 2011 under windows seven
6 REPLIES 6
1574 Views, 6 Replies
Hi everybody, i am trying to render a scene with the last versus of alias but i can't do this. the program works well except when it launch the render sub program. Windows detect an error and close it. I try to launch alias with compatibility mod or with administrator mod but no results. I have windows seven Integrale (the high french versus) in 32 bits.
Thanks for your help
6 REPLIES 6
JohnDixon8251
I have the same problem. Also running 7. As Windows detects a problem and closes the program, there is no way to see the Alias errorlog (I think).
anand_joshi
I am not getting this problem and I am on Win7 64-bit.
Maybe you can check with Autodesk support or your local channel partner of autodesk for this.
Regards
Anand
I have just downloaded the 2010 versus, i will try with it on this evening, i hope it will works properly attempting a update from autodesk.
JohnDixon8251
Anand_joshi, did you download your 2011 or have a disc?
John
Hi xklibur!
The render crash bug which happened on some x32 and x64 systems
running the different Alias versions is now squashed with the latest Hotfix.
The Hotfix also let you render out handy QTVR clips now, even on Win64
systems, after Apple finally fixed Quicktime to fully work on x64 systems.
Check out the Hotfix here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15158950&linkID=12268769
I hope this helps 🙂
That hotfix allows me to render now : )
