hello,
I'm having problems seeing certain toolbars since switching to a smaller monitor. I suspect my construction plane editor & blend curve toolbar are somewhere out of my smaller screen. Is there any posibility to bring them back on screen. Some reset function maybe or I don't know what.
Try deleting the Userprefs data.
It should be found on C:\Users\YOURNAME\AppData\Roaming\Autodesk\Alias.
Here you should find a folder named UserPrefs2014. Delete it.
Now when you start alias, it will create a brand new default user preferences setup.
It should fix it. Hopefully.
Good luck
Thanks but losing my shelf set and hotkeys is no option for me. This is exactly why I'm asking how to get windows back without deleting my prefsets.
