You can assign shortcut keys, to any functions, and has nothing to do with marking menus.
For Example, i have A for select nothing, S for select object , ALT A for delete, etc.
To be able to use shortcut keys, you need to activate PREFERENCES/INTERFACE/ToggleSingleHotkeys .
By default this is not ON, which means, when you press a key, you are inputing values on the top field, like 30 for and angle ETC.
After u enable the single hotkeys, u ll need to click in the input field to activate it, then write numbers in it if u need.
What i dont understand, is why you guys dont read the manual...
If you didnt understand, let me know, and i ll try to explain better.
I think u ll be alright, and i hope this was what you were looking for.
Good Luck!
Edited by
Discussion_Admin
