I finished my model,and reference to my rig file make setup.
but there's some problem.
if I change model file's shader,then from riging file reload model.
riging file's shader can not updata.
so why?
it's the maya2014 bug or mine?
what will i do?
THX
You should be aware that this is a ALIAS forum. Not MAYA.
Anyway, i ll give you a hint.
There is in a maya a tool called reference manager. Similar to 3ds max.
Check that on documentation, and you should be fine. Yeah, Maya is buggy (it is such a complex software), but there is always a workaround, and sometimes little tricks.
If you keep getting problems, send me a message here, and i will personally help you.
Good luck.
No. It is all maya default stuff.
Go to file menu, and you will see REFERENCE EDITOR there.
You may want to have a look too at some editors under WINDOW/GENERAL EDITORS/....., so u can check everything u need.
Have fun
