I'm assuming that Autodesk Showcase *used* to be Alias Design... if not,
read no further.
In Showcase, I've assigned a png file as a texture map for a material, but
all of the texture map manipulation controls are greyed out - I can't size
it, move it, rotate it, link the texture maps between the color and bump
maps - nothing.
I've tried this with multiple maps, multiple files - it's always greyed out.
I can see the maps on the objects after assigning the materials, but I
REALLY need to modify their UV parameters. Brick usually isn't 2" long...
Thanks in advance...
