Full Disclosure: I am very new to Alias.
I'm reverse engineering a mesh and have projected curves onto it then made an array of Fit Curves to work with. Before creating surfaces, I am working to tie endpoint CV's to other curves so everything is lined up.
Typically I use Pick Edit > Transform > Move and Curve Snap - works great. Then, occasionally, it just stops working. It lets me pick and snap, but when I release the left mouse button, the edit point just snaps back to its original location. If I close and restart, the operation works fine for a while until the same thing happens again.
Am I unwittingly getting into some state that I'm unaware of or is this possibly a 2014 "feature"?
Solved by ravenzep. Go to Solution.
