I upgraded my hardware (motherboard and CPU) and switched from windows 7 64bit to windows 8 64bit. Alias Design 2012 ran fine before, now after reinstalling it freezes after every operation (except rotating/zoom/move view) for about 20 seconds. Any idea what could cause this problem?
CPU before was an Intel E5400. Graphic drivers are up to date. Nvidia card didn't change.
System Diagnostics Log
Alias SysInfoCheck Version : 1.00.00
Date of Tune : Wed Jul 03 13:01:38 2013
Machine Configuration
Machine Name : --
Operating System : Microsoft (build 9200) <--- Windows 8 64Bit
Processor 1 : Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Number of Logical Cores : 1 <--- should be 4?
Memory Configuration
Total Physical Memory : 8128 MB
Available Physical Memory : 5830 MB
3D Device
Vendor : NVIDIA Corporation
Video Processor 1 : GeForce GTX 660
Video Memory : 2048 MB
Video Driver File Version : 9.18.13.2049
OpenGL Support
OpenGL Version : 4.3.0
OpenGL 2.0 - Supported
OpenGL Shader Objects - Supported
OpenGL Vertex Shader - Supported
OpenGL Fragment Shader - Supported
OpenGL Vertex Buffer Objects - Supported
OpenGL Frame Buffer Objects - Supported
Input/Pointing Devices
Device 1 : USB\VID_093A&PID_2510\7&2C919A59&0&5
Did you go to autodesk site and see the specs for Alias 2012?
Do you see anywehere it is to be run on win 8?
Do you think running something in win 8 with win 7 compatibility mode, will solve the problem?
