Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Advance Steel - Medidas
4 REPLIES 4
1032 Views, 4 Replies
Olá a todos,
Gostaria de saber, como mudar a unidade de medida do Advance Steel, ao invés de polegadas gostaria de deixar essas medidas em milímetros, porém as demais medidas do software já estão em milímetros, somente isso está errado.advance_steel.png
Obrigado desde já, Rafael
4 REPLIES 4
Emanuel.Nestor
Hello Rafael,
I hope you will understand English, because I don't know Portuguese 🙂
It seems that you have an English-US installation, suitable for USA, Canada or other countries that use Imperial system, not metric.
There are a lot of settings that depend on the installation system, and having Imperial installation will creates you problems for all phases.
That's why I recommend you to make another installation, using English International settings.
To do that, first you have to uninstall the current version.
Go to Control Panel, select Advance Steel and Uninstall.
After that, you have to manually delete the following folders:
C:\ -> ProgramData -> Autodesk -> Advance Steel 2015
C:\ -> Program Files -> Autodesk -> Advance Steel 2015
C:\ -> Program Files (x86) -> Autodesk -> Advance Steel 2015
Note: it is possible that not all the above folders exist on your computer.
Then you can make a new install.
You have to choose English International instead of English-US for Product language and content.
This choice is appears right after the license type and product information window.
Then you will have all the settings for Metric system.
Emy
Emy Nestor
in reply to: Emanuel.Nestor
Thanks, I did the procedure you sent me.
Subsequently try to ask questions in English.
Thanks a lot! You've helped me!
FCort
Hi @Anonymous,
How to install both versions (English-US and English international ) in the same computer?
Once in a while we can have projects from different countries.
