• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    ASE, SQL, OLE, ADE
    New Member
    dwg creation date from c++
    516 Views, 0 Replies
    05-31-2010 04:29 PM
    I'm trying to read autocad file creation date from c++. I don't mean system file creation date, but a drawing creation date (which remains unchanged when the document is copied somewhere else). To do this, I'm using the code as below (it is just a part of the whole). It works on doc and xls files but for dwg it shows "Not a compound file". Which is not true, because windows doesn't have a problem to read the statistics (creation date included) on dwg file.
    Any suggestions where to look for the problem, or how to do this for dwg ? Isn't dwg a compound document?
    The code:
    // Open the document as an OLE compound document.
          hr = ::StgOpenStorage(filename, NULL,
          STGM_READ | STGM_SHARE_EXCLUSIVE, NULL, 0, &pStorage);
          if(FAILED(hr)) {
             if(hr == STG_E_FILENOTFOUND)
                _stprintf_s(Result,MAX_PROPERTY_LENGTH,_T("File not found."));
             else if(hr == STG_E_FILEALREADYEXISTS)
                _stprintf_s(Result,MAX_PROPERTY_LENGTH,_T("Not a compound file."));
             else
                _stprintf_s(Result,MAX_PROPERTY_LENGTH,_T("StgOpenStorage() failed w/error %08lx"), hr);
             return DateResult;
    Please use plain text.
