ASE, SQL, OLE, ADE
*Urban, Peter
Message 1 of 9 (167 Views)
VBA run-time error opening database in AutoCAD 2000
167 Views, 8 Replies
01-21-2000 02:58 PM
We are working on a VBA application for a client. The application opens an
Access 97 database using the Microsoft DAO 3.51 Object Library reference. We
have found several computers at the clients site that produce the following
error:
"Run-time error 429 - ActiveX component can't create object"
The application stops at the following line:
Set dbLayout = Workspaces(0).OpenDatabase(strDbPath)
This same application has worked fine on many computers (Win98 and NT). We
have tried installing/re-installing AutoCAD 2000 and Microsoft Office 97 in
different orders with no luck.
Another application that is a Visual Basic .EXE (opening the same databse)
called from a VBA macro works fine on these computers. However the VBA
appllications using this databse error out on these computers.
Please help.
*Fleming, Jon
Message 2 of 9 (167 Views)
Re: VBA run-time error opening database in AutoCAD 2000
01-22-2000 04:42 AM in reply to: *Urban, Peter
You might try downloading and installing the latest MDAC from
http://www.microsoft.com/data. There is also a copy of MDAC on the AutoCAD
2000 disk somewhere (mdac_typ.exe), and an Autodesk employee would probably
suggest that you install that one because they know that one works with
AutoCAD. However, it's a little old by now.
Jrf
Member of the Autodesk Discussion Forum Moderator Program
> error:
*Urban, Peter
Message 3 of 9 (167 Views)
Re:
01-27-2000 11:06 AM in reply to: *Urban, Peter
We have tried this and it did not work. Any other suggestions would be
helpful. Thanks.
Jon Fleming wrote in message
news:VA.00000bbc.0caacbb3@fleming-group.com...
AutoCAD
probably
> Jrf
an
reference. We
following
> > error:
*Fleming, Jon
Message 4 of 9 (167 Views)
Re:
01-27-2000 02:53 PM in reply to: *Urban, Peter
Are you absolutely sure that the value of strDbPath is a valid value when
that line executes?
You could try re-writing your app to use ADO instead of DAO, but that is
probably a lot of work and I have no idea what chance of success there would
be.
jrf
> helpful. Thanks.
> AutoCAD
> probably
> > Jrf
> an
> reference. We
> following
> > > error:
*Urban, Peter
Message 5 of 9 (167 Views)
Re:
01-31-2000 07:10 AM in reply to: *Urban, Peter
Yes, I am sure the path is correct. The same code works fine on every other
computer we've tried, except for two (so far). Re-writing the code for ADO
is not really an option here. The two computers that didn't work were new
machines, out of the box. They had NT and AutoCAD (one had MS Office 97). So
far, nothing I've found from Microsoft has worked either. Has anyone else
had this happen?
Thanks.
news:VA.00000bc2.09be5291@fleming-group.com...
> that line executes?
would
> be.
> jrf
> > helpful. Thanks.
> > AutoCAD
> > probably
with
> > > Jrf
opens
> > an
> > reference. We
> > following
> > > > error:
*Mooney, Andy
Message 6 of 9 (167 Views)
Re:
02-22-2000 08:00 AM in reply to: *Urban, Peter
I am having the same problem. This was posted on vba group.
http://support.microsoft.com/support/kb/articles/Q185/1/26.ASP
Evidently it is an NT4 only problem. I still haven't remedy my situation.
Please let me know if you find a solution. Thanks Andy
Peter Urban wrote in message
news:8748nb$abn18@adesknews2.autodesk.com...
other
So
> had this happen?
> Thanks.
when
> > that line executes?
> would
> > be.
> > jrf
> > > helpful. Thanks.
> > > AutoCAD
> > > probably
> with
> > > > Jrf
> opens
> > > an
> > > reference. We
> > > following
> > > > > error:
*Urban, Peter
Message 7 of 9 (167 Views)
Re:
02-29-2000 08:27 AM in reply to: *Urban, Peter
This issues has not been resolved. We have searched through many Microsoft
articles and tried many proposed fixes. So far nothing has worked. Recently,
we have run into good old error 429 on a Windows 95 machine. Again, we can
not figure out the cause. Please help.
Peter Urban
Andy Mooney wrote in message
news:88ubr6$3je10@adesknews2.autodesk.com...
> other
ADO
new
97).
> So
else
> > had this happen?
> > Thanks.
> when
> > > that line executes?
is
> > would
> > > be.
> > > jrf
be
> > > > helpful. Thanks.
the
> > > > AutoCAD
> > > > probably
> > with
> > > > > Jrf
application
> > opens
> > > > an
> > > > reference. We
the
> > > > following
> > > > > > error:
*>, Hugo Valderhaug
Message 8 of 9 (167 Views)
Re:
03-15-2000 01:23 AM in reply to: *Urban, Peter
Maybe a registry / licencing key problem?
(all DAO dll's may be installed, but no licence key available).
In some cases adding the DAO licence key to NT registry has been sufficient,
in a few cases I have reinstalled DAO drivers. Never tried on W95.
I have seen the same behaviour with DAO from AutoCAD VBA,
and with DAO from MS Access code - not only as an Excel problem
as described in kb-article below.
Check address below for description and causes of problem,
and for instructions for manually adding DAO licence key
http://support.microsoft.com/support/kb/articles/q189/6/07.asp
Subj: DAO Error After Installing Visual Basic DAO Application
Hope this may help
regards
Hugo Valderhaug
Peter Urban wrote in msg<89gs1c$rv16@adesknews2.autodesk.com>...
Recently,
>Thanks,
>Peter Urban
New Member
mmorgan
Message 9 of 9 (167 Views)
05-03-2000 05:34 PM in reply to: *Urban, Peter
Peter,
I see this is rather old so with luck you have solved your problem. If not I may have a solution based on a similar situation. I had a VB app that ran *flawlessly* on 99.999 of the desktops I put it on. Except for 1 then there were 2 same error although mine was happening when I created an instantiantion of a Word object. Oddly, I could only duplicate the error on laptops that did not have VB (in one version or another) installed and were running Win98. The error was a missing version of (I believe) VBA50.dll. I discovered this by pasting my code out of the VB app into a Word VBA function and ran it which GPF'd me an all but also came up with the missing file spec (like I say my recollection is that it is VBA50.dll)> I copied the file to the windows\system directory on the offending laptops and that, as they say, was that.
Hope this helps you out.
Michael
You are not logged in.
Announcements
Need installation help?
Ask the Community
