• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    ASE, SQL, OLE, ADE
    *Swarbrick, Alan
    SQL statement fails with hyphenated column names
    171 Views, 2 Replies
    01-13-2000 03:09 AM
    Does anyone know who I can retrieve values from column names that have
    hyphens in them eg
    select * from .... works fine in R14 sqled
    select item, u-m from... does not.
    Alan
    Please use plain text.
    *Fleming, Jon
    Re: SQL statement fails with hyphenated column names
    01-13-2000 04:35 PM in reply to: *Swarbrick, Alan
    You're asking for trouble.
    Here's the theory, from the SQL standard.
    SQL recognizes two classes of identifiers (table names, column names,
    and the like). "Regular" identifiers do not contain any delimiter
    characters (such as spaces). "Delimited" identifiers contain delimiter
    characters or are SQL keywords. Delimited identifiers _must_ be
    surrounded with double quotes in the SQL statement. Regular identifiers
    _may_ be surrounded with double quotes in the SQL statement.
    Piece o' cake, huh? You might think that you can just surround all your
    identifiers with double quotes and you're home free. But here's the
    unfortunate facts.
    AutoCAD R14 requires you to use double quotes around identifiers when it
    wants you to, and will not allow you to use double quotes around
    identifiers when it doesn't want you to. When it wants double quotes
    and when it doesn't is not documented. AutoCAD never requires double
    quotes around an identifier that is not an SQL keyword, is upper case,
    and contains only characters from the set A-Z, 0-9, and _ (underscore).
    Use anything that doesn't fit those constraints and you're on your own.
    I have seen supposedly identical systems running identical versions of
    AutoCAD and identical LISP programs, and on one system AutoCAD wanted
    double quotes and on the other it wouldn't accept them.
    So the following might work:
    (setq SQLStatement "SELECT ITEM, \"U-M\" FROM ...")
    but it might fail on some machines. If you do see it work on some and
    fail on others, and find out why, I'd love to know.
    My free library, DBL202.ZIP from http://www.cadalog.com, contains a few
    functions that allow you to dynamically find out what form AutoCAD
    wants. But they're not 100% guaranteed to work with table names (they
    work 100% with column names) and they are s l o w. The code required
    to use them gets pretty convoluted. Feel free to download DBL and look
    at them.
    jrf
    Member of the Autodesk Discussion Forum Moderator Program
    > hyphens in them eg
    *Fleming, Jon
    01-14-2000 04:12 AM in reply to: *Swarbrick, Alan
    One thing I forgot to say about R14's requirements on double quotes;
    they are, of course, required wherever the SQL standard requires them
    (when the identifier contains delimiters or is an SQL keyword). The
    example you gave does not require quotes in SQL, but AutoCAD may require
    them.
    jrf
    > hyphens in them eg
