ASE, SQL, OLE, ADE
New Member
tommyzh
Message 1 of 2 (315 Views)
Run-time Error -'2145320928 (80210020)'
315 Views, 1 Replies
04-20-2009 12:14 PM
I developed a VBA application. In the application, I asked user to click on a AutoCAD drawing and get a return point. My code is as follows:
Dim blockRefObj As AcadBlockReference
If pick_insert_pointCheckBox.Value Then 'if user choose to pick an insert point by himself
Me.Hide
Dim returnPnt As Variant
returnPnt = ThisDrawing.Utility.GetPoint(, "Enter or pick up the insert point: ")
Dim cen(0 To 2) As Double
cen(0) = returnPnt(0): cen(1) = returnPnt(1): cen(2) = 0
Else
cen(0) = 0: cen(1) = 0: cen(2) = 0
I can run this without problem in the design mode. The i created a tool button. But if I run this from the tool button, I always got stopped by an error message "Run-time Error -'2145320928 (80210020)', User input is a keyword. When the program stopped, the debug window show the code and marked "returnPnt = ThisDrawing.Utility.GetPoint(, "Enter or pick up the insert point: ")" in yellow. I guess this is the problem. But if I hit run again, it goes on without problem.
Anybody can help? Thank you very much.
Active Contributor
mhardine
Message 2 of 2 (274 Views)
Re: Run-time Error -'2145320928 (80210020)'
08-30-2011 10:34 AM in reply to: tommyzh
I get same thing. Have you figured it out?
You are not logged in.
Announcements
Need installation help?
Ask the Community
