• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    ASE, SQL, OLE, ADE
    *Davidson, Gary
    Rename an Attribute Tag
    68 Views, 4 Replies
    01-20-2000 09:02 AM
    Easy enough, except when you've got data already in the attribute, in over
    50 drawings.
    Here's the scenario. Someone in our office created a block to identify
    doors. The block has two attributes which are named "DOOR#" and "Room#".
    Besides the fact that I don't think it's proper to name attributes using the
    number symbol, they both work fine in the drawings. The trouble comes when
    we try to extract the data. The only data that we're able to extract is the
    Door Number. The Room Number is left blank in the extraction file, even
    though the extraction template includes it.
    The extraction template looks like this:
    DOOR# C016000
    ROOM# C016000
    The columns of extracted text look something like this '2049A',''
    Note that the bonehead who created this block used both upper and lower case
    in the tag names (besides the number symbol). This is the only difference I
    can see between these tags and apparently it is the cause of this problem.
    If I do an attredef and rename the tag, the extraction works fine - EXCEPT -
    that the default values are put into the attribute instead of the previously
    entered room number values. Presumably this is because the name of the tag
    has changed, so the values no longer know where to go. (Yes, I've tried
    entering the tag names in the extraction file in both upper and lower cases,
    switching their order, etc.)
    Has anyone seen a utility or lisp routine which will allow me to rename the
    tag, redefine the block, and retain the stored attribute values?
    Any help greatly appreciated.
    Gary Davidson
    gdavi@yahoo.com
    Please use plain text.
    *Furman, Paul
    Re: Rename an Attribute Tag
    01-20-2000 03:47 PM in reply to: *Davidson, Gary
    Have you tried attredef? There are others but this one comes with r14 I think.
    Not sure how well it works.
    > 50 drawings.
    > DOOR# C016000
    > ROOM# C016000
    > Gary Davidson
    > gdavi@yahoo.com
    *Davidson, Gary
    Re:
    01-20-2000 05:48 PM in reply to: *Davidson, Gary
    Paul
    Problem with attredef is that if you rename the tag, the attribute values
    are lost. Thanks for the response, though.
    I later found a tool bundled with the Acad Express Tools called Block
    Attribute Manager that did the trick.
    Gary
    Paul Furman wrote in message
    news:38879E93.E016AE3@edgehill.net...
    think.
    over
    > > 50 drawings.
    the
    when
    the
    > > DOOR# C016000
    > > ROOM# C016000
    case
    difference I
    problem.
    EXCEPT -
    previously
    tag
    cases,
    the
    > > Gary Davidson
    > > gdavi@yahoo.com
    *Brunke, Frank
    Re:
    01-24-2000 06:01 PM in reply to: *Davidson, Gary
    Although this doesn't help with renaming the tags, is it possible that the
    "bonehead" mixed his "0" and "o" between rooms and number tags. Maybe the lower
    case o was actually a zero. That would account for "no extraction".
    I say that from first person "bonehead" experience.
    As long as you mentioned ATTREDEF, Does it work differently in R 14 and A2K
    I recently had to redefine several tags and found that ATTREDEF changed new
    insertions of the block, but left alone existing instances, while A2K updated
    both.
    Frank
    > Paul
    > Gary
    > think.
    > over
    > > > 50 drawings.
    > the
    > when
    > the
    > > > DOOR# C016000
    > > > ROOM# C016000
    > case
    > difference I
    > problem.
    > EXCEPT -
    > previously
    > tag
    > cases,
    > the
    > > > Gary Davidson
    > > > gdavi@yahoo.com
    *Davidson, Gary
    Re:
    01-24-2000 06:29 PM in reply to: *Davidson, Gary
    Frank...
    I too have first hand bonehead experience at the "0" and "o" confusion. Not
    this time though. Having seen this before, it's one of the first things I
    checked.
    As for the attredef question, I personally haven't seen any differences in
    the command since R11 or so. I always changes both the old and new inserts
    for me.
    Gary
    Frank Brunke wrote in message
    news:388D03E2.CFC7FE67@fmbcad.com...
    lower
    A2K
    new
    updated
    > both.
    > Frank
    > > Paul
    values
    > > Gary
    I
    > > think.
    in
    > > over
    > > > > 50 drawings.
    identify
    "Room#".
    using
    > > the
    comes
    > > when
    is
    > > the
    even
    > > > > DOOR# C016000
    > > > > ROOM# C016000
    lower
    > > case
    > > difference I
    > > problem.
    > > EXCEPT -
    > > previously
    the
    > > tag
    tried
    lower
    > > cases,
    rename
    > > the
    > > > > Gary Davidson
    > > > > gdavi@yahoo.com
