• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    ASE, SQL, OLE, ADE
    New Member
    tpohara
    LISP, AutoCAD 2011 and the Oracle initial Connection code
    421 Views, 0 Replies
    08-27-2011 12:50 PM
    I am using AutoCAd 2011 and Oracle 9.3. I am using the 'Oracle Provider for OLE DB' I am very familiar with AutoCAd and with Oracle and connection between the client and the server Oracle portions.
    Inside of AutoCAD I can connect fine using the dbconnect menu. I am able to query etc with AutoCAD. No issues there.
    I am UNABLE  to get LISP to connect no matter what I try. This seems like a very commoon issue for many developers (based on what I can see from a google query).
    I am having trouble the getting the initial connection to work in LISP.
    As you can see I am trying to use the ADOLISP library.
    I would appreciate any input.
    Thanks in advance.
    Code example:
      (setq ConnectString "Driver=OraOLEDB.Oracle;DBQ=TEST_SID;UID=TestAdmin;Pwd=test")
      (prompt (strcat "\n\nConnecting to the database using \n\""
                      ConnectString
      (if (not (setq ConnectionObject
                      (ADOLISP_ConnectToDB ConnectString "TESTAdmin" "test")
        (progn
          (prompt "\nConnection failed!")
          (ADOLISP_ErrorPrinter)
        (prompt "\nResult: succeeded!")
    Error:
    "Driver=OraOLEDB.Oracle;DBQ=TEST_SID;UID=TESTAdmin;Pwd=test"
    Connection failed!
    Visual LISP message           Automation Error. [Microsoft][ODBC Driver
    Manager] Data source name not found and no default driver specified
    Description        [Microsoft][ODBC Driver Manager] Data source name not found
    HelpContext        0
    HelpFile
    NativeError        0
    Number              -2147467259
    SQLState      IM002
    Source              Microsoft OLE DB Provider for ODBC Drivers
    Please use plain text.
