• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    ASE, SQL, OLE, ADE
    *Wang, Weslley X
    How I can know if I connect to database in LISP
    118 Views, 3 Replies
    01-12-2000 11:17 AM
    Hello:
    I am working with a Map Util project. I try to make a Link Path.
    before I do it, I have to check if the same name Link Path existed. If
    there are no same name Link Path existed, I will create one. when I
    tested my code, I found it crashed a lot. because there so many case I
    can not determine:
    a drawing with database connected or not, a drawing with database
    attached or not, If I connect a database and then disconnect it, the
    condition is not like one before I connect the database.
    Here is my code:
    (defun connect (table keyfield lpn)
    (cond (trace_functions (princ "\nSubroutine: Connect")))
    (setq connectionok nil)
    (setvar "cmddia" 0)
    (princ "\nVerifying database connection to the ")
    (princ table)
    (princ " table. Please wait.")
    ;; The following segment was added on August 16 to CONFIRM connection
    to a database table.
    (if (member (list table keyfield lpn) connectionlist)
    (progn ;; If the table we are searching for is already in the list
    of connected tables
    (setq sqlstr (strcat "SELECT * FROM " odbcschema "." table))
    (if (null session)
    (setq session (asi_connect odbcname username passwrod))
    ) ;_ end of if
    (setq statement (asi_prepare session sqlstr))
    (if statement ;If the statement creation is NOT valid, go through
    the connection process.
    (progn (setq connectionok T) (asi_deallocstm statement))
    ) ;_ end of if
    ) ;_ end of progn
    ) ;_ end of if
    (if (not connectionok)
    (progn
    (setq dostatus (ase_dostatus (ase_lppath lpn))) ;Set the database
    object status
    (if (= dostatus 18) ;If the status is not confirmed...
    (progn (command "aseadmin" "environment" odbcname "exit")
    (setq dostatus (ase_dostatus (ase_lppath lpn))) ;Update the
    database object status
    (if (= dostatus 18) ;If the status is still unconfirmed...
    (progn (princ "\nPerforming full connection to environment ")
    (princ odbcname)
    (command "aseadmin" "environment" odbcname "options" "connect"
    username password "exit" "exit")
    ) ;_ end of progn
    ) ;_ end of
    ) ;_ end of progn
    ) ;_ end of
    (cond ;;
    ((and (= (substr (ase_docurrent) 1 (strlen odbcname)) odbcname)
    (null dostatus))
    (princ (strcat "\nCreating Link Path Name " (strcase lpn)))
    (command "aseadmin" "catalog" "CAD" "schema" odbcschema
    "table" table "options"
    "link-paths" "new" keyfield "" lpn "set" lpn
    "exit" "exit" "exit"
    ) ;_ end of command
    ((null dostatus)
    "connect" username password
    "" "catalog" "CAD" "schema" odbcschema "table"
    table "options"
    lpn
    ) ;_ end of command
    ((= dostatus 10)
    "exit" "Table" table "options" "link-paths"
    "n" keyfield
    "" lpn "exit" "exit" "exit"
    ) ;_ end of command
    ((< dostatus 14)
    (command "aseadmin" "Table" table "options" "link-paths" "n"
    keyfield "" lpn "exit" "exit" "exit")
    ) ;_ end of cond
    ) ;_ end of progn
    (progn ;;
    (if (and (= (substr (ase_docurrent) 1 (strlen odbcname)) odbcname)
    (null dostatus))
    (progn ;;
    lpn
    ) ;_ end of command
    ) ;_ end of progn
    ) ;_ end of if
    ) ;_ end of progn
    ) ;_ end of
    (if (null session)
    (setq session (asi_connect odbcname username password)) ;Connect to
    the ODBC connection.
    ) ;_ end of if
    (if (not (member (list table keyfield lpn) connectionlist))
    (setq connectionlist (append connectionlist (list (list table
    keyfield lpn))))
    ) ;_ end of
    (setvar "cmddia" 1)
    (princ)
    ) ;_ end of function CONNECT
    ;; end of code
    If you can help, thanks a lot
    Weslley X Wang
    I am working on Map 3, Windows NT 4. SP3 with Pentium Pro 200, 128 MB
    memory,
    Please use plain text.
    *Fleming, Jon
    Re: How I can know if I connect to database in LISP
    01-12-2000 02:37 PM in reply to: *Wang, Weslley X
    I don't have much experience with LPNs and Displayable Attributes.
    However, you might find DBL202.ZIP from http://www.cadalog.com useful (in
    the portions of your program where you execute SQL statements directly).
    jrf
    Member of the Autodesk Discussion Forum Moderator Program
    In article <387CD32C.9FECD3BB@autodes.com>, Weslley X Wang wrote:
    > Hello:
    > can not determine:
    *DS
    Re:
    02-10-2000 07:43 PM in reply to: *Wang, Weslley X
    Jon,
    Once again, that web site is still showing a message that they are down with
    hardware failures (2/10/00). Anyway you could post that file here somehow?
    Maybe in teh Customer Files section?
    Thanks! Dave Stein
    "Jon Fleming" wrote in message
    news:VA.00000b96.04ef44f9@fleming-group.com...
    > ...you might find DBL202.ZIP from http://www.cadalog.com useful
    *Fleming, Jon
    Re:
    02-11-2000 04:27 AM in reply to: *Wang, Weslley X
    OK.
    jrf
    In article <8800bg$seu2@adesknews2.autodesk.com>, Ds wrote:
    > Jon,
    > Thanks! Dave Stein
