ASE, SQL, OLE, ADE
*JIC
Message 1 of 5 (79 Views)
Excel question
79 Views, 4 Replies
12-05-2002 11:19 PM
I am looking for a good location of information regarding inserting
information from excel into autocad.
any info is appreciated
Phil
*Dotson, Terry W.
Message 2 of 5 (79 Views)
Re: Excel question
12-06-2002 02:52 AM in reply to: *JIC
What exactly are you looking to do?
Terry
*JIC
Message 3 of 5 (79 Views)
Re:
12-06-2002 03:32 AM in reply to: *JIC
use it for my plumbing/mechanical calcs that i have set up in excel.
> Terry
*Goodfellow, John
Message 4 of 5 (79 Views)
Re: Excel question
12-06-2002 04:24 AM in reply to: *JIC
Take a look at the ACAD help file "ActiveX and VBA Developers Guide", Ch.
12. Here's a code sample. Include a ref. to the Excel 8.0 object library
in your ACAD VBA project.
Private Sub UseExcel(strFSpecXLS As String)
' strFSpecXLS is the full path + filename + ext of the Excel file
Dim oExcel As Excel.Application, oWrkBk As Excel.Workbook, oWrkSh As
Excel.Worksheet
If Dir(strFSpecXLS) <> "" Then
Set oExcel = New Excel.Application
Set oWrkBk = oExcel.Workbooks.Open(strFSpecXLS)
Set oWrkSh = oWrkBk.Worksheets("WorksheetName")
' Assign input values to cells
' oSensor is a class object
' oRecSet is an ADO recordset contained in oSensor
oWrkSh.[C8] = oSensor.oRecSet!GlaWid
oWrkSh.[C9] = oSensor.oRecSet!GlaHgt
oWrkSh.[C10] = oSensor.oRecSet!ActWid
oWrkSh.[C11] = oSensor.oRecSet!ActHgt
' Run calculations
oWrkSh.Calculate
' Return output values to recordset
oSensor.oRecSet!TGRTopMax = oWrkSh.[D24]
oSensor.oRecSet!TGRTopMin = oWrkSh.[C24]
oSensor.oRecSet!TGRGlaMax = oWrkSh.[H24]
oSensor.oRecSet!TGRGlaMin = oWrkSh.[G24]
Else
Err.Raise vbObjectError + 9998, strThisProc, "File not found: " &
strFSpecXLS
oWrkBk.Close True ' True means "save the workbook changes"
oExcel.Quit
End Sub
John Goodfellow
irtfnm
use john at goodfellowassoc dot com
"JIC" wrote in message
news:3DF0C00E.5000508@netscape.net...
> Phil
*Dotson, Terry W.
Message 5 of 5 (79 Views)
Re:
12-08-2002 10:21 PM in reply to: *JIC
And then produce a table in the drawing, or draw those as objects?
Terry
You are not logged in.
Announcements
Need installation help?
Ask the Community
