• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    ASE, SQL, OLE, ADE
    *Inc., Viljoen Architect
    Excel 97 --> R2000 problems/questions
    74 Views, 4 Replies
    01-17-2000 01:44 PM
    Hi everyone,
    I have a question about using Excel charts. It's nice to try and get the
    automation of Excel into AutoCAD, but it is difficult to figure out. I have
    a chart done up in Excel...not too big. about 25 rows & maybe 12 columns.
    When inserted, you don't get to see the whole chart, only a small portion of
    it. If I close the drawing and then reopen it, the whole chart is visible,
    but it has tons of empty cells to make it (the chart) square shaped. I have
    no idea how to get R2000 to only display a certain range of cells. Is there
    even a way to do this? It's driving me nuts!
    Thanks in advance.
    Brian
    Brian Majerus
    Dipl. Arch. Tech.
    Viljoen Architect Inc.
    300 A Wilson Avenue
    Downsview, Ontario M3H 1S8
    Tel: (416) 630-2255 extension 147
    Fax: (416) 630-4782
    Direct Email: bmajerus@viljoenarch.com
    General Email: info@viljoenarch.com
    Viljoen Architect Inc. retains the copyright in all drawings, plans,
    sketches, and all digital information. They may not be used for any
    other projects or purposes without the written consent of Viljoen
    Architect Inc. Failure to do so will result in legal action.
    Please use plain text.
    *Support, Fletcher Clover - Autodesk GIS
    Re: Excel 97 --> R2000 problems/questions
    01-18-2000 09:40 AM in reply to: *Inc., Viljoen Architect
    To display the data contained in the Excel spreadsheet, there must be at
    least one named range of cells. This name corresponds to a table name in
    Access and is displayed under the Tables branch of the Data Source.
    Create at least one named range of cells in the Excel spreadsheet (do not
    use DATABASE or other reserved words when naming the cell range).
    Important: When you select a range of cells to name, select one row and one
    column either side of the extents of the data in the range you are naming.
    Otherwise, even though the name of the range is shown as a table below the
    Data Source in the Project Manager; there is no content
    when the table is opened.
    To create a named range of cells in Microsoft Excel, select the cells and
    then name them using the Name Box to the left of the formula bar. When you
    attach an Excel file with at least one named range of cells, there is a
    table with the relative fields and values in the Data Sources section of the
    Project Workspace. This table represents the named range of cells.
    I hope this helps,
    Fletcher
    Viljoen Architect Inc. wrote in message
    news:8602g1$a2p20@adesknews2.autodesk.com...
    > Hi everyone,
    have
    of
    visible,
    have
    there
    > Thanks in advance.
    > Brian
    > Brian Majerus
    > Dipl. Arch. Tech.
    > 300 A Wilson Avenue
    > Fax: (416) 630-4782
    *Fleming, Jon
    Re:
    01-18-2000 02:37 PM in reply to: *Inc., Viljoen Architect
    I think he is doing a pasted OLE link rather than a database-type lookup.
    jrf
    Member of the Autodesk Discussion Forum Moderator Program
    In article <8628ii$fre4@adesknews2.autodesk.com>, Fletcher Clover - Autodesk
    GIS Product Support wrote:
    > Hi,
    > I hope this helps,
    > Fletcher
    > > Hi everyone,
    > have
    > of
    > visible,
    > have
    > there
    > > Thanks in advance.
    > > Brian
    > > Brian Majerus
    > > Dipl. Arch. Tech.
    > > 300 A Wilson Avenue
    > > Fax: (416) 630-4782
    *Furman, Paul
    01-18-2000 06:39 PM in reply to: *Inc., Viljoen Architect
    Brian,
    OLE in acad is crummy. Paste special as autocad entities for the best look (& no
    link) or look into add-on programs such as at http://www.dotsoft.com Perhaps
    with the next release oc acad... I don't believe 2000 fixes this situation?
    Paul
    "Viljoen Architect Inc." wrote:
    > Hi everyone,
    > Thanks in advance.
    > Brian
    > Brian Majerus
    > Dipl. Arch. Tech.
    > 300 A Wilson Avenue
    > Fax: (416) 630-4782
    *DS
    Re:
    02-03-2000 07:44 PM in reply to: *Inc., Viljoen Architect
    Actually, there are two to blame. Microsoft is addressing some known issues
    with OLE in Windows 2000, while Autodesk is working on some issues with OLE
    in the next release of AutoCAD (I'm told by unnamed sources). One of these
    "issues" relates to the problems of plot rotation with embedded or linked
    OLE objects such as Word and Excel documents or clips.
    DS
