3Ds Max'de kullanılan klavye kısayollarını inceliyoruz. Başlıkları bilerek türkçe yazmadık, çoğu kişi ingilizce olarak bildiği için ingilizce olarak hazırladık.
Viewport
F – Front view
L – Left view
R – Right view
T – Top view
B – Bottom view
C – Camera view
P – Perspective view
D – Disable Viewport
MMB – Pan
Alt + MMB – Orbit
Ctrl + Alt + MMB – Zoom
Z – Zoom on Currently Selected Object
Shift + Ctrl + Z – Zoom All
F Keys
F1 – Help
F2 – Shade Selected Faces Toggle
F3 – Wireframe / Smooth+Highlights Toggle
F4 – View Edged Faces Toggle
F9 – Render
F10 – Render Setup Dialog
F12 – Transform Type-In Dialog
Display Options
G – Show / Hide Grid
J – Show / Hide Selection Bracket
X – Gizmo Display Toggle On / Off
Alt + B – Viewport Background Dialog
Alt + Q – Isolation Mode
Alt + X – Display Selected Object as See-Through
Alt + H – Hide Selected Polygons
Alt + I – Hide Unselected Polygons
Alt + U – Unhide Hidden Polygons
Shift + F – Show Safe Frames Toggle
Object Selection and Transformation Tools
Q – Select Tool
W – Select & Move Tool
E – Select & Rotate Tool
R – Select & Scale Tool
Sub Object Selection Modes
(The numbers listed below refer to the top row of number keys above the alpha keys on your keyboard)
1 – Vertex Sub Object Selection Mode
2 – Edge Sub Object Selection Mode
3 – Border Sub Object Selection Mode
4 – Polygon Sub Object Selection Mode
5 – Element Sub Object Selection Mode
Selection Tools
H – Select from Scene Dialog
Alt + L – Select Sub Object Loop
Alt + R – Select Sub Object Ring
Ctrl + A – Select All
Ctrl + D – Deselect All
Ctrl + I – Invert Current Sub Object Selection (Polygons, Vertices, Edges)
Ctrl + Page-Up – Grow Polygon Selection
Ctrl + Page-Down – Shrink Polygon Selection
Hold Ctrl Key and click to add to selection set
Hold Alt Key and click to remove from selection set
Spacebar – Selection Lock Toggle
Object Editing Tools
A – Angle Snap Toggle
S – Snaps Toggle
Alt + A – Align Tool
Alt + P – Cap Polygon for Current Border Selection
Alt + C – Cut Poly Tool
Ctrl + V – Clone Selected Object
Shift + E – Extrude Selected Polygon(s)
Cameras
C – Switch to Camera View
Ctrl + C – Create Camera from Current View
Shift + C – Hide Cameras
Lights
Shift + L – Hide Lights Toggle
Materials
M – Materials Editor
Environment & Rendering
F9 – Render
8 (keyboard) – Environment and Effects Dialog
0 (keyboard) – Render to Texture Dialog
Shift + Q – Quick Render
Other Useful Shortcut Keys
Ctrl + N – New File
Ctrl + O – Open File
Ctrl + S – Save File
Ctrl + X – Expert Mode Toggle
+ & – (keyboard) – Increase and Decrease Gizmo Size
7 (keyboard) – Toggle “Show Statistics”
Çözüldü! Çözüme gidin.
SerdarHakann tarafından çözüldü. Çözüme gidin.
File altındaki import yada export seçeneklerine tıklayamıyorum. Mause imlecine üstüne getirdiğimde seçenekler penceresi kapanıyor. ama diğer Main lerde olmuyor (Tools) vs. sadece file altındaki seçeneklerde oluyor ve export, import, alamıyorum. nedeni nedir? yada bu seçeneklerin kısa yolları var mı. İyi Forumlar.
sisteminizde yer alan max.ini dosyasını silerek tekrar deneyebilirsiniz.
paylaşım için teşekkürler. programdaki kısa yolları kişisel olarak nereden değiştirebiliyorduk yardımcı olabilir misiniz?
Merhaba, Programdaki Kısayolları Kendinize Göre Konfigüre Etmek İçin
Üst Sekmedeki
Customize / Customize User Interface Kısımına Girdikten Sonra Category : All Command ( Tüm Komutlar ) Kısımının Seçili Olduğunu Görürsünüz.
İstediğiniz Bir Komuta Tıklayıp, Sağ Taraftaki Hot Key Kısımından istediğiniz şekilde Kısayolunuzu Atayabilirsiniz..
Örnek Görseller Ekledim ... Faydalı Olması Dileği ile.
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ile ödüllendirin.
Mehmet Akif TOPLU
Autodesk Expert Elite / Instructor / CG Artist
Hocam teşekkür ederim sık kullandığım ayarları ayarlama yardımcı oldunuz 🙂
merhabalar hocam f tuşları program açıkken komut bazında kullanamıyorum..mesela f3 tuşu basınca ses ayarı yapılıyor..labtop yenı onun ayarlarından da kaynaklanıyor olabılır ama f tuşlarını programda nasıl aktif edebilirim bilemedim?
Merhaba @filiz2769
Ses Açılma Sorunu Fn Tuşu'nun Aktif Olmasından Dolayı Olabilir. Klavye Üzerinde Fn Tuşuna Basarak F3 e Bastığınız zaman sorun çözülecektir..
Tamamen Fn Tuşu Pasif Hale de Getirebilirsiniz..
FN tuşunu kapatmak, FN tuşunu pasif hale getirmek için;
Klavyeden Shift + Numlock veya Capslock + Numlock Tuşları ile Çözülebilir. Bu Tuşlar Bilgisayarın Marka Modeline göre de değişkenlik gösterebilir..
Eğer Bunları Yapmadan Düzenlemek İsterseniz FN + F3 Tuşlarını Beraber Kullanmanız Gerekecek Bu Tarz İşlemlerde.
İyi Çalışmalar.
Mehmet Akif TOPLU
Dediğiniz gibi Fn tuşuyla deneyince komutlar gerçekleşiyor yalnız yazdığınız gibi Fn tuşunu pasifize edemedim bi türlü..muhtemelen labtop modeliyle alakalı.. Dell in İ7 işlemcisini kullanıyorum..teşekkürler yardımcı olduğunuz için
Rica Ederim @filiz2769
İnternet'ten Laptop'unuzun Marka modelini yazıp aratma şansınız olursa bulabilirsiniz diye tahmin ediyorum.
İyi Çalışmalar.
Mehmet Akif TOPLU
Merhaba
3dsmaxte F4 ve F3 tuşları algılamıyor.Ses ayarı ve f4 yan tarafta alakasız birşey çıkıyor.
Yardımcı olursanız sevinirim
Merhaba @busracan95
Klavyenızdeki FN tuşu üzerinden eliniz basılı kalarak f3 ve f4'e basıp denerseniz sorununuza çözüm olabilir.
İyi çalışmalar.
Mehmet Akif TOPLU
3dsmax 2018 de roofgen scripti yükleyemedim ayrıca çatı nasıl oluşturabilirim ? yardımcı olursanız sevinirim
Merhaba @busracan95
@izzetalsan hocamızın videosunda mevcut kontrol edip sonuca ulaşabilirsiniz.
https://www.izzetalsan.com/3ds-max-ile-cati-yapimi-3ds-max-ile-cati-modelleme/
İyi Çalışmalar.
Mehmet Akif TOPLU
Merhaba @busracan95
Snap Toogle'nın açık kalmış Kısayol "S" tuşu ile kapatabilirsiniz
İyi Çalışmalar.
Mehmet Akif TOPLU
Aradığınızı bulamadınız mı? Topluluğa sorun veya bilgilerinizi paylaşın.
