3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
mental ray texturing
3 REPLIES 3
dutch4years
895 Views, 3 Replies
so....... i am trying to make a beserk sword i textured it in substance painter but i when i export i get multiple maps see photo does any one know how to apply these so my model in 3ds max?
 ,dutch4years
3 REPLIES 3
Daf
in reply to: dutch4years
Max doesn't do metal/rough exactly as you see in Painter but you can get close. Delete those maps - go back to Painter and export using the Vray preset. This will convert your materials into maps Max can use. Best to export as 16bit tiff. Then use  Arch & Design material - going by memory only  here but...
difuse (or base color) into difuse,
glossy into Reflection Glossiness Map,
IOR into IOR Map
Bump into Normal Bump - then your normal and height into that
I've had good luck with the metal/rough materials using the new Physical Material and the ART renderer as a pbr flow.
Search for non pbr - for more info
This is a good tutorial for the non PBR flow - it uses Vray but can be converted for Mental Ray as it non PBR
https://gumroad.com/musashidan#
Good luck!
Daf
3DS Max 2020.3
i7-4790 @4GHz • 32GB • GTX 1080/8GB • Windows 7 Pro
dutch4years
in reply to: Daf
YOU ARE A HERO it worked thank you so much!!
Daf
Great! You're more than welcome!
3DS Max 2020.3
