When I render a billboard of a tree ( has an opacity channel ) through multiscatter in mental ray , the image appears mostly transparent ( see attached image ). The opacity channel is set to 100%. Any help would be greatly appreciated.
Solved by mhouse777s. Go to Solution.
Hi @mhouse777s,
Could you provide the Max file so I may take a look at it and see what might be happening there?
Thanks so much!
Thanks Dominique.
When you render the scene you'll see the foreground tree's themselves are transparent. I put the original billboard tree to the right for comparison( not transparent) . Once the billboard is duplicated by multiscatter it becomes see through for some reason.
Thanks.
Hello @mhouse777s,
Dominique, Jon Bell, and I have been looking at this scene for a bit now from a 3ds Max perspective and there doesn't seem to be anything wrong here about the Max scene itself. Sadly, there is no demo version of multiscatter that I can find so I've been unable to test it on the multiscatter level. However I did come across the forums for this plugin and perhaps you can get more directed help there. It may be that the plugin simply needs to be updated. Thank you for your understanding.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Hello @mhouse777s,
Thanks for the update, I'm glad it worked out for you. Have a great week!
Best Regards,
