3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Backburner render issue - Error retrieving configuration file
10 REPLIES 10
Message 1 of 11
Quintussmit
3212 Views, 10 Replies
Hi
When I submit a network render job to backburner in Max I get the error message "Error retrieving configuration file"?
What is this file and what is the fix.
I am rendering with Mental Ray
Max 2009 Design, Backburner 2008.1, Vista Ultimate 64 bit, 4Gb Ram
tx
10 REPLIES 10
Message 2 of 11
Quintussmit
in reply to: Quintussmit
Thank you to Nicolas from Autodesk support for pointing me to this:
Issue
When you clicked the Render button to submit a network render job, the following error message was displayed:
Solution
This error indicates a problem writing to the Program Files\Backburner 2 folder. This may occur because of insufficient user permissions or incorrect security settings for this folder and its subfolders. Users must have a minimum of Power User rights and must have Full Control permissions to all files and folders contained in the Backburner 2\Network folder.
I gave full control to this folder for my user account and everything worked fine.
Message 3 of 11
Good tip, I just ran into that issue myself. The mentioned solution worked perfectly.
Message 4 of 11
mail
sorry,
but I can not find the folder Backburner 2
you can tell the complete path?
thanks.
win 7 64 bit-max 2012-
Message 5 of 11
jeff
With BB 2008.1, the folder should be C:\Program Files (x86)\Autodesk\Backburner
-jeff
Max since 1992 (3d Studio) · Win 10-64 · Wintel workstation · 64 GB RAM · nVidia Quadro RTX 4000 · BB render garden via Deadline
Message 6 of 11
hi
I've got this problem since i've installed backburner 2012 and max 2012.
The problem is still there after trying all kind of authorization on the backburner folder, several install, cleaning registry, etc.
I got Win7 pro 64 and i loose several hours to find a solution on the net but nothing change !
Help please !
Message 7 of 11
adamk
We are having the same problem with permissions and Win 7. Works in Admin profiles, but no other. Even after making the entire 'C drive' full control, the user can't start Backburner server on some computers.
Anyone figure this out yet?
Message 8 of 11
Hi
I’ve solved my problem !
I replace the backburner.xml file in
C:\Users\"username"\AppData\Local\Autodesk\3dsMax\2012 - 64bit\enu\BackBurner (3ko)
by the one in
C:\Users\"username"\AppData\Local\backburner (8ko)
(these paths are for windows 7)
and it worked immediately (no need to restart max)
hope it will help
Message 9 of 11
thekwen
Hi
by the one in
hope it will help
Autodesk support solution didn't worked for me but your did the job astrolau so many thanks man...
Kwen
Message 10 of 11
Pixelschmiede
Hi
by the one in
hope it will help
Kwen
the solution of thekwen did work for me too. thanks man you saved my a... 🙂
best regards
themaxxer
Message 11 of 11
does the xml file need to be replaced on the servers?
