Здравствуйте!
Помогите, пожалуйста, разобраться, почему не устанавливается 3ds max
2014/9/7:20:11:28 1 1-ПК === Setup started on 1-ПК by 1 ===
2014/9/7:20:11:28 1 1-ПК Path_Length: 151
2014/9/7:20:11:28 1 1-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm
2014/9/7:20:11:28 1 1-ПК Launch
2014/9/7:20:11:28 1 1-ПК CommandLine
2014/9/7:20:11:28 1 1-ПК Current Directory C:\Users\1\AppData\Local\Temp\_AI276D.tmp
2014/9/7:20:11:35 1 1-ПК === Setup ended ===
2014/9/7:20:11:29 1 1-ПК === Setup started on 1-ПК by 1 ===
2014/9/7:20:11:29 1 1-ПК Path_Length: 151
2014/9/7:20:11:29 1 1-ПК Current Directory C:\Users\1\AppData\Local\Temp\_AI276D.tmp
2014/9/7:20:11:29 1 1-ПК Launch
2014/9/7:20:11:35 1 1-ПК PageOpen LaunchDialog
2014/9/7:20:11:40 1 1-ПК PageOpen LicenseDialog
2014/9/7:20:11:42 1 1-ПК PageOpen ProductInfoDialog
2014/9/7:20:12:06 1 1-ПК PageOpen ProductSelectionDialog2
2014/9/7:20:12:10 1 1-ПК PageOpen FullProgressDialog
2014/9/7:20:12:10 1 1-ПК Installing DirectX® Runtime: "C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/9/7:20:13:37 1 1-ПК Install DirectX® Runtime Succeeded
2014/9/7:20:13:37 1 1-ПК Installing Autodesk® Material Library 2014 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/7:20:14:15 1 1-ПК Install Autodesk® Material Library 2014 - Medium Resolution Library Succeeded
2014/9/7:20:14:17 1 1-ПК Installing Autodesk® 3ds Max 2014: TRANSFORMS="C:\Users\1\AppData\Local\Temp\_AI276D.tmp\x64\max\3dsMax2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/7:20:25:15 1 1-ПК Install Autodesk® 3ds Max 2014 Failed Installation aborted, Result=1603
2014/9/7:20:25:27 1 1-ПК Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded
2014/9/7:20:25:27 1 1-ПК Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Установите всё поотдельности:
C:\Autodesk\Autodesk_3ds_Max_Design_2015_EFGJKS_Win_64bit_dlm\3rdParty
Вчастности сам макс:
Andrey Plaksin CG Artist
portfolio
Facebook |Personal project
Находите сообщения полезными? Поставьте Нравится (Like) этим сообщениям!
На ваш вопрос успешно ответили? Нажмите кнопку 'Утвердить решение'
Не нашли то, что искали? Задайте вопросы в сообществе или поделитесь своими знаниями.
