Всем привет.
Не устанавливается 3ds Max, можете помочь определить причину
2014/11/22:22:01:14 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/22:22:01:14 Dmitry DMITRY-ПК Launch
2014/11/22:22:01:53 Dmitry DMITRY-ПК === Setup ended ===
2014/11/22:22:01:20 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/22:22:01:20 Dmitry DMITRY-ПК Launch
2014/11/22:22:02:09 Dmitry DMITRY-ПК PageOpen LaunchDialog
2014/11/22:22:02:43 Dmitry DMITRY-ПК PageOpen LicenseDialog
2014/11/22:22:03:03 Dmitry DMITRY-ПК PageOpen LaunchDialog
2014/11/22:22:03:08 Dmitry DMITRY-ПК PageOpen LicenseDialog
2014/11/22:22:03:11 Dmitry DMITRY-ПК PageOpen ProductInfoDialog
2014/11/22:22:03:18 Dmitry DMITRY-ПК PageOpen ProductSelectionDialog2
2014/11/22:22:03:21 Dmitry DMITRY-ПК PageOpen FullProgressDialog
2014/11/22:22:03:21 Dmitry DMITRY-ПК Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dmitry\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/11/22:22:05:25 Dmitry DMITRY-ПК Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2014/11/22:22:05:27 Dmitry DMITRY-ПК PageOpen InstallCompleteDialog
2014/11/22:22:06:33 Dmitry DMITRY-ПК === Setup ended ===
2014/11/22:22:22:25 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/22:22:22:25 Dmitry DMITRY-ПК Launch
2014/11/22:22:22:54 Dmitry DMITRY-ПК === Setup ended ===
2014/11/22:22:22:31 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/22:22:22:31 Dmitry DMITRY-ПК Launch
2014/11/22:22:22:56 Dmitry DMITRY-ПК PageOpen LaunchDialog
2014/11/22:22:23:53 Dmitry DMITRY-ПК PageOpen LicenseDialog
2014/11/22:22:24:27 Dmitry DMITRY-ПК PageOpen ProductInfoDialog
2014/11/22:22:24:45 Dmitry DMITRY-ПК PageOpen ProductSelectionDialog2
2014/11/22:22:24:48 Dmitry DMITRY-ПК PageOpen FullProgressDialog
2014/11/22:22:24:49 Dmitry DMITRY-ПК Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dmitry\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/11/22:22:25:52 Dmitry DMITRY-ПК Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2014/11/23:14:05:02 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/23:14:05:02 Dmitry DMITRY-ПК Launch
2014/11/23:14:05:10 Dmitry DMITRY-ПК === Setup ended ===
2014/11/23:14:05:04 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/23:14:05:04 Dmitry DMITRY-ПК Launch
2014/11/23:14:05:12 Dmitry DMITRY-ПК PageOpen LaunchDialog
2014/11/23:14:05:28 Dmitry DMITRY-ПК PageOpen LicenseDialog
2014/11/23:14:05:28 Dmitry DMITRY-ПК PageOpen ProductSelectionDialog2
2014/11/23:14:05:47 Dmitry DMITRY-ПК PageOpen LicenseDialog
2014/11/23:14:05:47 Dmitry DMITRY-ПК PageOpen LaunchDialog
2014/11/23:14:05:54 Dmitry DMITRY-ПК PageOpen BeginDeploymentDialog
2014/11/23:14:06:05 Dmitry DMITRY-ПК PageOpen LaunchDialog
2014/11/23:14:06:20 Dmitry DMITRY-ПК PageOpen LicenseDialog
2014/11/23:14:06:59 Dmitry DMITRY-ПК PageOpen ProductInfoDialog
2014/11/23:14:07:53 Dmitry DMITRY-ПК PageOpen ProductSelectionDialog2
2014/11/23:14:07:56 Dmitry DMITRY-ПК PageOpen FullProgressDialog
2014/11/23:14:07:57 Dmitry DMITRY-ПК Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dmitry\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/11/23:14:08:23 Dmitry DMITRY-ПК Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2014/11/23:14:08:24 Dmitry DMITRY-ПК PageOpen InstallCompleteDialog
2014/11/23:14:09:06 Dmitry DMITRY-ПК === Setup ended ===
2014/11/23:14:22:44 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/23:14:22:44 Dmitry DMITRY-ПК Launch
2014/11/23:14:22:57 Dmitry DMITRY-ПК === Setup ended ===
2014/11/23:14:22:49 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/23:14:22:49 Dmitry DMITRY-ПК Launch
2014/11/23:14:22:58 Dmitry DMITRY-ПК PageOpen LaunchDialog
2014/11/23:14:23:39 Dmitry DMITRY-ПК PageOpen LicenseDialog
2014/11/23:14:23:44 Dmitry DMITRY-ПК PageOpen ProductInfoDialog
2014/11/23:14:24:28 Dmitry DMITRY-ПК PageOpen ProductSelectionDialog2
2014/11/23:14:24:43 Dmitry DMITRY-ПК PageOpen FullProgressDialog
2014/11/23:14:24:43 Dmitry DMITRY-ПК Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dmitry\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/11/23:14:25:07 Dmitry DMITRY-ПК Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2014/11/23:14:25:09 Dmitry DMITRY-ПК PageOpen InstallCompleteDialog
2014/11/23:14:25:38 Dmitry DMITRY-ПК === Setup ended ===
2014/11/23:15:04:36 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/23:15:04:36 Dmitry DMITRY-ПК Launch
2014/11/23:15:04:41 Dmitry DMITRY-ПК === Setup ended ===
2014/11/23:15:04:37 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/23:15:04:37 Dmitry DMITRY-ПК Launch
2014/11/23:15:04:43 Dmitry DMITRY-ПК PageOpen LaunchDialog
2014/11/23:15:05:00 Dmitry DMITRY-ПК PageOpen LicenseDialog
2014/11/23:15:05:05 Dmitry DMITRY-ПК PageOpen ProductInfoDialog
2014/11/23:15:05:08 Dmitry DMITRY-ПК PageOpen ProductSelectionDialog2
2014/11/23:15:05:10 Dmitry DMITRY-ПК PageOpen FullProgressDialog
2014/11/23:15:05:10 Dmitry DMITRY-ПК Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dmitry\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/11/23:15:05:30 Dmitry DMITRY-ПК Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2014/11/23:15:05:31 Dmitry DMITRY-ПК PageOpen InstallCompleteDialog
2014/11/23:15:05:53 Dmitry DMITRY-ПК === Setup ended ===
2014/11/23:16:44:06 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/23:16:44:06 Dmitry DMITRY-ПК Launch
2014/11/23:16:44:13 Dmitry DMITRY-ПК === Setup ended ===
2014/11/23:16:44:07 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/23:16:44:07 Dmitry DMITRY-ПК Launch
2014/11/23:16:44:14 Dmitry DMITRY-ПК PageOpen LaunchDialog
2014/11/23:16:46:53 Dmitry DMITRY-ПК PageOpen LicenseDialog
2014/11/23:16:46:56 Dmitry DMITRY-ПК PageOpen ProductInfoDialog
2014/11/23:16:46:58 Dmitry DMITRY-ПК PageOpen ProductSelectionDialog2
2014/11/23:16:47:01 Dmitry DMITRY-ПК PageOpen FullProgressDialog
2014/11/23:16:47:02 Dmitry DMITRY-ПК Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dmitry\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/11/23:16:47:21 Dmitry DMITRY-ПК Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2014/11/23:16:47:22 Dmitry DMITRY-ПК PageOpen InstallCompleteDialog
2014/11/23:16:47:35 Dmitry DMITRY-ПК === Setup ended ===
2014/11/23:18:20:56 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/23:18:20:56 Dmitry DMITRY-ПК Launch
2014/11/23:18:21:07 Dmitry DMITRY-ПК === Setup ended ===
2014/11/23:18:21:11 Dmitry DMITRY-ПК PageOpen LaunchDialog
2014/11/23:18:21:27 Dmitry DMITRY-ПК PageOpen LicenseDialog
2014/11/23:18:21:34 Dmitry DMITRY-ПК PageOpen ProductInfoDialog
2014/11/23:18:21:37 Dmitry DMITRY-ПК PageOpen ProductSelectionDialog2
2014/11/23:18:21:40 Dmitry DMITRY-ПК PageOpen FullProgressDialog
2014/11/23:18:21:40 Dmitry DMITRY-ПК Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dmitry\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/11/23:18:22:01 Dmitry DMITRY-ПК Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2014/11/23:18:22:01 Dmitry DMITRY-ПК PageOpen InstallCompleteDialog
2014/11/23:18:22:10 Dmitry DMITRY-ПК === Setup ended ===
2014/11/23:21:38:51 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/23:21:38:51 Dmitry DMITRY-ПК Launch
2014/11/23:21:39:03 Dmitry DMITRY-ПК === Setup ended ===
2014/11/23:21:38:52 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/23:21:38:52 Dmitry DMITRY-ПК Launch
2014/11/23:21:39:05 Dmitry DMITRY-ПК PageOpen LaunchDialog
2014/11/23:21:39:20 Dmitry DMITRY-ПК PageOpen LicenseDialog
2014/11/23:21:39:24 Dmitry DMITRY-ПК PageOpen ProductInfoDialog
2014/11/23:21:39:27 Dmitry DMITRY-ПК PageOpen ProductSelectionDialog2
2014/11/23:21:39:29 Dmitry DMITRY-ПК PageOpen FullProgressDialog
2014/11/23:21:39:29 Dmitry DMITRY-ПК Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dmitry\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/11/23:21:39:52 Dmitry DMITRY-ПК Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2014/11/23:21:39:53 Dmitry DMITRY-ПК PageOpen InstallCompleteDialog
2014/11/23:21:39:58 Dmitry DMITRY-ПК === Setup ended ===
2014/11/23:21:44:51 Dmitry DMITRY-ПК === Setup started on DMITRY-ПК by Dmitry ===
2014/11/23:21:44:51 Dmitry DMITRY-ПК Launch
2014/11/23:21:45:01 Dmitry DMITRY-ПК === Setup ended ===
2014/11/23:21:45:02 Dmitry DMITRY-ПК PageOpen LaunchDialog
2014/11/23:21:45:31 Dmitry DMITRY-ПК PageOpen LicenseDialog
2014/11/23:21:45:36 Dmitry DMITRY-ПК PageOpen ProductInfoDialog
2014/11/23:21:45:38 Dmitry DMITRY-ПК PageOpen ProductSelectionDialog2
2014/11/23:21:45:41 Dmitry DMITRY-ПК PageOpen FullProgressDialog
2014/11/23:21:45:41 Dmitry DMITRY-ПК Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Dmitry\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/11/23:21:45:56 Dmitry DMITRY-ПК Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
Andrey Plaksin CG Artist
portfolio
Facebook |Personal project
Находите сообщения полезными? Поставьте Нравится (Like) этим сообщениям!
На ваш вопрос успешно ответили? Нажмите кнопку 'Утвердить решение'
Андрюша, ты все таки как Expert Elite, не переставай скидывать ссылки на решеные проблемы. Начинающим форумчанам сложно бывает.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
@olegshahmurzof wrote:
не записал серийный номер когда закачивал автокад помогите пожалуйста
Обратитесь с этим вопросом, к вашему поставщику ПО.
Aleksey Borisov / Алексей Борисов
Blog Revit | Forum Revit | YouTube - Revit
I am an EXPERT ELITE member
Чаты в TELEGRAM и форумы про Revit:
https://t.me/bim_help -- https://t.me/prorubim_bim_chat -- https://forum.bim2b.ru/
olegshahmurzof написано:
Почему вы пишите об этом в теме про 3ds max?
Все серийные номера хранятся в вашем профиле и на студенческом портале, если вы используете студенческую версию.
P.S. Просьба создать отдельное обсуждение по вашей проблеме
Помогите пожалуйста установить 3ds max 2016. При начале остановке постоянно "вылазит" такое окно (на скрине). Выбор другого раздела не помогает.
у меня Win10 x64, студенческая лицензия
UPD: Проблема решена, извините за беспокойство
Не нашли то, что искали? Задайте вопросы в сообществе или поделитесь своими знаниями.
