Сообщество
Не устанавливается 3ds max 2014,раньше устанавливался и нормально работал,пришлось удалить,теперь не могу установить 😄 ,почистил вручную реестр - не помогает,если что ОС Windows 7.
СПАСИБО ЗА РАНЕЕ ТЕМ КТО ПОМОЖЕТ
Лог установки :
2014/5/27:15:28:54 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:15:28:54 User USER-ПК Launch 2014/5/27:15:28:54 User USER-ПК CommandLine /P {52B37EC7-D836-0409-0064-3C24BCED2010} /M MAX /LANG en-us 2014/5/27:15:29:14 User USER-ПК === Setup ended === 2014/5/27:15:28:57 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:15:28:57 User USER-ПК Launch 2014/5/27:15:29:09 User USER-ПК PageOpen MaintenanceDialog 2014/5/27:15:29:15 User USER-ПК PageOpen MaintVerifyReadyDialog 2014/5/27:15:29:17 User USER-ПК PageOpen FullProgressDialog 2014/5/27:15:29:17 User USER-ПК Installing Autodesk® 3ds Max 2014: REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/27:15:32:37 User USER-ПК Uninstall Autodesk® 3ds Max 2014 Succeeded 2014/5/27:15:32:37 User USER-ПК PageOpen MaintCompleteDialog 2014/5/27:15:32:44 User USER-ПК === Setup ended === 2014/5/27:16:42:35 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:16:42:35 User USER-ПК Path_Length: 151 2014/5/27:16:42:35 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US 2014/5/27:16:42:35 User USER-ПК Launch 2014/5/27:16:42:35 User USER-ПК CommandLine 2014/5/27:16:42:35 User USER-ПК Path_Length: 151 2014/5/27:16:42:35 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI2960.tmp 2014/5/27:16:42:40 User USER-ПК === Setup ended === 2014/5/27:16:42:36 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:16:42:36 User USER-ПК Path_Length: 151 2014/5/27:16:42:36 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI2960.tmp 2014/5/27:16:42:36 User USER-ПК Launch 2014/5/27:16:42:41 User USER-ПК === Setup ended === 2014/5/27:16:42:44 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:16:42:44 User USER-ПК Path_Length: 151 2014/5/27:16:42:44 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US 2014/5/27:16:42:44 User USER-ПК Launch 2014/5/27:16:42:44 User USER-ПК CommandLine 2014/5/27:16:42:44 User USER-ПК Path_Length: 151 2014/5/27:16:42:44 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI4B32.tmp 2014/5/27:16:42:51 User USER-ПК === Setup ended === 2014/5/27:16:42:45 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:16:42:45 User USER-ПК Path_Length: 151 2014/5/27:16:42:45 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI4B32.tmp 2014/5/27:16:42:45 User USER-ПК Launch 2014/5/27:16:42:55 User USER-ПК === Setup ended === 2014/5/27:16:43:11 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:16:43:11 User USER-ПК Path_Length: 151 2014/5/27:16:43:11 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US 2014/5/27:16:43:11 User USER-ПК Launch 2014/5/27:16:43:11 User USER-ПК CommandLine 2014/5/27:16:43:11 User USER-ПК Path_Length: 151 2014/5/27:16:43:11 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIB4DD.tmp 2014/5/27:16:43:16 User USER-ПК === Setup ended === 2014/5/27:16:43:12 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:16:43:12 User USER-ПК Path_Length: 151 2014/5/27:16:43:12 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIB4DD.tmp 2014/5/27:16:43:12 User USER-ПК Launch 2014/5/27:16:43:17 User USER-ПК === Setup ended === 2014/5/27:16:44:08 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:16:44:08 User USER-ПК Path_Length: 151 2014/5/27:16:44:08 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US 2014/5/27:16:44:08 User USER-ПК Launch 2014/5/27:16:44:08 User USER-ПК CommandLine 2014/5/27:16:44:08 User USER-ПК Path_Length: 151 2014/5/27:16:44:08 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI956B.tmp 2014/5/27:16:44:11 User USER-ПК === Setup ended === 2014/5/27:16:44:09 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:16:44:09 User USER-ПК Path_Length: 151 2014/5/27:16:44:09 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI956B.tmp 2014/5/27:16:44:09 User USER-ПК Launch 2014/5/27:16:44:12 User USER-ПК === Setup ended === 2014/5/27:16:48:03 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:16:48:03 User USER-ПК Path_Length: 151 2014/5/27:16:48:03 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US 2014/5/27:16:48:03 User USER-ПК Launch 2014/5/27:16:48:03 User USER-ПК CommandLine 2014/5/27:16:48:03 User USER-ПК Path_Length: 151 2014/5/27:16:48:03 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI2838.tmp 2014/5/27:16:48:05 User USER-ПК === Setup ended === 2014/5/27:16:48:03 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:16:48:03 User USER-ПК Path_Length: 151 2014/5/27:16:48:03 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI2838.tmp 2014/5/27:16:48:03 User USER-ПК Launch 2014/5/27:16:48:06 User USER-ПК === Setup ended === 2014/5/27:17:07:35 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:17:07:35 User USER-ПК Path_Length: 151 2014/5/27:17:07:35 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm 2014/5/27:17:07:35 User USER-ПК Launch 2014/5/27:17:07:35 User USER-ПК CommandLine 2014/5/27:17:07:35 User USER-ПК Path_Length: 151 2014/5/27:17:07:35 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI8F6.tmp 2014/5/27:17:08:13 User USER-ПК === Setup ended === 2014/5/27:17:07:51 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:17:07:51 User USER-ПК Path_Length: 151 2014/5/27:17:07:51 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI8F6.tmp 2014/5/27:17:07:51 User USER-ПК Launch 2014/5/27:17:08:02 User USER-ПК PageOpen LaunchDialog 2014/5/27:17:19:17 User USER-ПК PageOpen LicenseDialog 2014/5/27:17:19:20 User USER-ПК PageOpen ProductInfoDialog 2014/5/27:17:26:05 User USER-ПК PageOpen ProductSelectionDialog2 2014/5/27:17:26:19 User USER-ПК PageOpen FullProgressDialog 2014/5/27:17:26:19 User USER-ПК Installing DirectX® Runtime: "C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/5/27:17:28:29 User USER-ПК Install DirectX® Runtime Succeeded 2014/5/27:17:28:29 User USER-ПК Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/27:17:29:15 User USER-ПК Install Autodesk® Material Library 2014 Succeeded 2014/5/27:17:29:16 User USER-ПК Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/27:17:29:46 User USER-ПК Install Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/27:17:29:46 User USER-ПК Installing Autodesk® Material Library 2014 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/27:17:31:43 User USER-ПК Install Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/27:17:31:47 User USER-ПК Installing Autodesk® 3ds Max 2014: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AI8F6.tmp\x64\max\3dsMax2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/27:17:32:06 User USER-ПК Install Autodesk® 3ds Max 2014 Failed Installation aborted, Result=1603 2014/5/27:17:32:18 User USER-ПК Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/27:17:32:26 User USER-ПК Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/27:17:32:40 User USER-ПК Rollback Autodesk® Material Library 2014 Succeeded 2014/5/27:17:32:40 User USER-ПК Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/5/27:17:32:41 User USER-ПК PageOpen InstallCompleteDialog 2014/5/27:17:33:05 User USER-ПК === Setup ended === 2014/5/27:17:34:20 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:17:34:20 User USER-ПК Path_Length: 151 2014/5/27:17:34:20 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI7F9C.tmp 2014/5/27:17:34:20 User USER-ПК Launch 2014/5/27:17:34:22 User USER-ПК [Error: 1056] An instance of the service is already running. 2014/5/27:17:34:22 User USER-ПК === Setup ended === 2014/5/27:17:34:18 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:17:34:18 User USER-ПК Path_Length: 151 2014/5/27:17:34:18 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US 2014/5/27:17:34:18 User USER-ПК Launch 2014/5/27:17:34:18 User USER-ПК CommandLine 2014/5/27:17:34:18 User USER-ПК Path_Length: 151 2014/5/27:17:34:18 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI7F9C.tmp 2014/5/27:17:34:26 User USER-ПК === Setup ended === 2014/5/27:17:34:54 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:17:34:54 User USER-ПК Path_Length: 151 2014/5/27:17:34:54 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIF73B.tmp 2014/5/27:17:34:54 User USER-ПК Launch 2014/5/27:17:34:56 User USER-ПК PageOpen LaunchDialog 2014/5/27:17:34:58 User USER-ПК PageOpen LicenseDialog 2014/5/27:17:34:48 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:17:34:48 User USER-ПК Path_Length: 151 2014/5/27:17:34:48 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm 2014/5/27:17:34:48 User USER-ПК Launch 2014/5/27:17:34:48 User USER-ПК CommandLine 2014/5/27:17:34:48 User USER-ПК Path_Length: 151 2014/5/27:17:34:48 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIF73B.tmp 2014/5/27:17:35:02 User USER-ПК === Setup ended === 2014/5/27:17:35:00 User USER-ПК PageOpen ProductInfoDialog 2014/5/27:17:35:19 User USER-ПК PageOpen ProductSelectionDialog2 2014/5/27:17:36:13 User USER-ПК PageOpen FullProgressDialog 2014/5/27:17:36:13 User USER-ПК Installing DirectX® Runtime: "C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/5/27:17:37:32 User USER-ПК Install DirectX® Runtime Succeeded 2014/5/27:17:37:32 User USER-ПК Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/27:17:37:46 User USER-ПК Install Autodesk® Material Library 2014 Succeeded 2014/5/27:17:37:46 User USER-ПК Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/27:17:38:13 User USER-ПК Install Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/27:17:38:13 User USER-ПК Installing Autodesk® Material Library 2014 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/27:17:38:56 User USER-ПК Install Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/27:17:38:59 User USER-ПК Installing Autodesk® 3ds Max 2014: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AIF73B.tmp\x64\max\3dsMax2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/27:17:39:31 User USER-ПК Install Autodesk® 3ds Max 2014 Failed Installation aborted, Result=1603 2014/5/27:17:39:41 User USER-ПК Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/27:17:39:52 User USER-ПК Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/27:17:40:05 User USER-ПК Rollback Autodesk® Material Library 2014 Succeeded 2014/5/27:17:40:05 User USER-ПК Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/5/27:17:40:05 User USER-ПК PageOpen InstallCompleteDialog 2014/5/27:17:47:47 User USER-ПК === Setup ended === 2014/5/27:17:49:05 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:17:49:05 User USER-ПК Path_Length: 151 2014/5/27:17:49:05 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm 2014/5/27:17:49:05 User USER-ПК Launch 2014/5/27:17:49:05 User USER-ПК CommandLine 2014/5/27:17:49:05 User USER-ПК Path_Length: 151 2014/5/27:17:49:05 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIB76.tmp 2014/5/27:17:49:07 User USER-ПК === Setup ended === 2014/5/27:17:49:06 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:17:49:06 User USER-ПК Path_Length: 151 2014/5/27:17:49:06 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIB76.tmp 2014/5/27:17:49:06 User USER-ПК Launch 2014/5/27:17:49:07 User USER-ПК PageOpen LaunchDialog 2014/5/27:17:49:08 User USER-ПК PageOpen LicenseDialog 2014/5/27:17:49:10 User USER-ПК PageOpen ProductInfoDialog 2014/5/27:17:49:37 User USER-ПК PageOpen ProductSelectionDialog2 2014/5/27:17:49:44 User USER-ПК PageOpen FullProgressDialog 2014/5/27:17:49:44 User USER-ПК Installing DirectX® Runtime: "C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/5/27:17:51:17 User USER-ПК Install DirectX® Runtime Succeeded 2014/5/27:17:51:17 User USER-ПК Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/27:17:51:32 User USER-ПК Install Autodesk® Material Library 2014 Succeeded 2014/5/27:17:51:32 User USER-ПК Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/27:17:51:55 User USER-ПК Install Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/27:17:51:55 User USER-ПК Installing Autodesk® Material Library 2014 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/27:17:53:19 User USER-ПК Install Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/27:17:53:20 User USER-ПК Installing Autodesk® 3ds Max 2014: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AIB76.tmp\x64\max\3dsMax2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/27:17:53:39 User USER-ПК Install Autodesk® 3ds Max 2014 Failed Installation aborted, Result=1603 2014/5/27:17:53:54 User USER-ПК Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/27:17:54:05 User USER-ПК Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/27:17:54:20 User USER-ПК Rollback Autodesk® Material Library 2014 Succeeded 2014/5/27:17:54:20 User USER-ПК Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/5/27:17:54:20 User USER-ПК PageOpen InstallCompleteDialog 2014/5/27:18:06:49 User USER-ПК === Setup ended === 2014/5/27:19:10:42 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:19:10:42 User USER-ПК Path_Length: 151 2014/5/27:19:10:42 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm 2014/5/27:19:10:42 User USER-ПК Launch 2014/5/27:19:10:42 User USER-ПК CommandLine 2014/5/27:19:10:42 User USER-ПК An instance of setup is already running. Only one instance of setup can run at a time.2014/5/27:19:10:45 User USER-ПК === Setup ended === 2014/5/27:19:09:31 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:19:09:31 User USER-ПК Path_Length: 151 2014/5/27:19:09:31 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm 2014/5/27:19:09:31 User USER-ПК Launch 2014/5/27:19:09:31 User USER-ПК CommandLine 2014/5/27:19:09:31 User USER-ПК Path_Length: 151 2014/5/27:19:09:31 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIDE3D.tmp 2014/5/27:19:10:58 User USER-ПК === Setup ended === 2014/5/27:19:09:55 User USER-ПК === Setup started on USER-ПК by User === 2014/5/27:19:09:55 User USER-ПК Path_Length: 151 2014/5/27:19:09:55 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIDE3D.tmp 2014/5/27:19:09:55 User USER-ПК Launch 2014/5/27:19:10:37 User USER-ПК PageOpen LaunchDialog 2014/5/27:19:10:47 User USER-ПК PageOpen LicenseDialog 2014/5/27:19:10:50 User USER-ПК PageOpen ProductInfoDialog 2014/5/27:19:11:15 User USER-ПК PageOpen ProductSelectionDialog2 2014/5/27:19:11:40 User USER-ПК PageOpen FullProgressDialog 2014/5/27:19:11:40 User USER-ПК Installing DirectX® Runtime: "C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/5/27:19:14:48 User USER-ПК Install DirectX® Runtime Succeeded 2014/5/27:19:14:49 User USER-ПК Installing Autodesk® 3ds Max 2014: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AIDE3D.tmp\x64\max\3dsMax2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/27:19:15:39 User USER-ПК Install Autodesk® 3ds Max 2014 Failed Installation aborted, Result=1603 2014/5/27:19:15:40 User USER-ПК Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/5/27:19:15:40 User USER-ПК PageOpen InstallCompleteDialog 2014/5/27:19:18:11 User USER-ПК === Setup ended === 2014/5/28:01:02:17 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:01:02:17 User USER-ПК Path_Length: 151 2014/5/28:01:02:17 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm 2014/5/28:01:02:17 User USER-ПК Launch 2014/5/28:01:02:17 User USER-ПК CommandLine 2014/5/28:01:02:17 User USER-ПК Path_Length: 151 2014/5/28:01:02:17 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AID9A2.tmp 2014/5/28:01:03:02 User USER-ПК === Setup ended === 2014/5/28:01:02:32 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:01:02:32 User USER-ПК Path_Length: 151 2014/5/28:01:02:32 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AID9A2.tmp 2014/5/28:01:02:32 User USER-ПК Launch 2014/5/28:01:02:49 User USER-ПК PageOpen LaunchDialog 2014/5/28:01:02:52 User USER-ПК PageOpen LicenseDialog 2014/5/28:01:02:55 User USER-ПК PageOpen ProductInfoDialog 2014/5/28:01:04:26 User USER-ПК PageOpen ProductSelectionDialog2 2014/5/28:01:07:00 User USER-ПК PageOpen FullProgressDialog 2014/5/28:01:07:01 User USER-ПК Installing DirectX® Runtime: "C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/5/28:01:11:02 User USER-ПК Install DirectX® Runtime Succeeded 2014/5/28:01:11:02 User USER-ПК Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:01:12:07 User USER-ПК Install Autodesk® Material Library 2014 Succeeded 2014/5/28:01:12:07 User USER-ПК Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:01:13:03 User USER-ПК Install Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/28:01:13:03 User USER-ПК Installing Autodesk® Material Library 2014 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:01:15:24 User USER-ПК Install Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/28:01:15:27 User USER-ПК Installing Autodesk® 3ds Max 2014: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AID9A2.tmp\x64\max\3dsMax2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:01:16:01 User USER-ПК Install Autodesk® 3ds Max 2014 Failed Installation aborted, Result=1603 2014/5/28:01:16:16 User USER-ПК Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/28:01:16:30 User USER-ПК Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/28:01:16:52 User USER-ПК Rollback Autodesk® Material Library 2014 Succeeded 2014/5/28:01:16:52 User USER-ПК Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/5/28:01:16:53 User USER-ПК PageOpen InstallCompleteDialog 2014/5/28:01:17:32 User USER-ПК === Setup ended === 2014/5/28:02:36:20 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:02:36:20 User USER-ПК Path_Length: 151 2014/5/28:02:36:20 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm 2014/5/28:02:36:20 User USER-ПК Launch 2014/5/28:02:36:20 User USER-ПК CommandLine 2014/5/28:02:36:21 User USER-ПК Path_Length: 151 2014/5/28:02:36:21 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIEE6B.tmp 2014/5/28:02:37:08 User USER-ПК === Setup ended === 2014/5/28:02:36:39 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:02:36:39 User USER-ПК Path_Length: 151 2014/5/28:02:36:39 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIEE6B.tmp 2014/5/28:02:36:39 User USER-ПК Launch 2014/5/28:02:36:59 User USER-ПК PageOpen LaunchDialog 2014/5/28:02:38:19 User USER-ПК PageOpen LicenseDialog 2014/5/28:02:39:34 User USER-ПК PageOpen ProductInfoDialog 2014/5/28:02:39:59 User USER-ПК PageOpen ProductSelectionDialog2 2014/5/28:02:40:19 User USER-ПК PageOpen FullProgressDialog 2014/5/28:02:40:20 User USER-ПК Installing DirectX® Runtime: "C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/5/28:02:42:52 User USER-ПК Install DirectX® Runtime Succeeded 2014/5/28:02:42:52 User USER-ПК Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:02:43:50 User USER-ПК Install Autodesk® Material Library 2014 Succeeded 2014/5/28:02:43:51 User USER-ПК Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:02:44:39 User USER-ПК Install Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/28:02:44:40 User USER-ПК Installing Autodesk® Material Library 2014 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:02:46:58 User USER-ПК Install Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/28:02:46:59 User USER-ПК Installing Autodesk® 3ds Max 2014: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AIEE6B.tmp\x64\max\3dsMax2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:02:47:27 User USER-ПК Install Autodesk® 3ds Max 2014 Failed Installation aborted, Result=1603 2014/5/28:02:47:39 User USER-ПК Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/28:02:47:51 User USER-ПК Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/28:02:48:11 User USER-ПК Rollback Autodesk® Material Library 2014 Succeeded 2014/5/28:02:48:11 User USER-ПК Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/5/28:02:48:12 User USER-ПК PageOpen InstallCompleteDialog 2014/5/28:03:01:33 User USER-ПК === Setup ended === 2014/5/28:03:07:42 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:03:07:42 User USER-ПК Path_Length: 151 2014/5/28:03:07:42 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm 2014/5/28:03:07:42 User USER-ПК Launch 2014/5/28:03:07:42 User USER-ПК CommandLine 2014/5/28:03:07:42 User USER-ПК Path_Length: 151 2014/5/28:03:07:42 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIB015.tmp 2014/5/28:03:07:55 User USER-ПК === Setup ended === 2014/5/28:03:07:45 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:03:07:45 User USER-ПК Path_Length: 151 2014/5/28:03:07:45 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIB015.tmp 2014/5/28:03:07:45 User USER-ПК Launch 2014/5/28:03:07:48 User USER-ПК PageOpen LaunchDialog 2014/5/28:03:07:55 User USER-ПК PageOpen LicenseDialog 2014/5/28:03:07:59 User USER-ПК PageOpen ProductInfoDialog 2014/5/28:03:17:30 User USER-ПК === Setup ended === 2014/5/28:03:17:57 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:03:17:57 User USER-ПК Path_Length: 151 2014/5/28:03:17:57 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm 2014/5/28:03:17:57 User USER-ПК Launch 2014/5/28:03:17:57 User USER-ПК CommandLine 2014/5/28:03:17:57 User USER-ПК Path_Length: 151 2014/5/28:03:17:57 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI12DD.tmp 2014/5/28:03:18:03 User USER-ПК === Setup ended === 2014/5/28:03:18:00 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:03:18:00 User USER-ПК Path_Length: 151 2014/5/28:03:18:00 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI12DD.tmp 2014/5/28:03:18:00 User USER-ПК Launch 2014/5/28:03:18:02 User USER-ПК PageOpen LaunchDialog 2014/5/28:03:18:04 User USER-ПК PageOpen LicenseDialog 2014/5/28:03:18:07 User USER-ПК PageOpen ProductInfoDialog 2014/5/28:03:18:24 User USER-ПК === Setup ended === 2014/5/28:03:21:35 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:03:21:35 User USER-ПК Path_Length: 151 2014/5/28:03:21:35 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm 2014/5/28:03:21:35 User USER-ПК Launch 2014/5/28:03:21:35 User USER-ПК CommandLine 2014/5/28:03:21:35 User USER-ПК Path_Length: 151 2014/5/28:03:21:35 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI67B0.tmp 2014/5/28:03:21:38 User USER-ПК === Setup ended === 2014/5/28:03:21:37 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:03:21:37 User USER-ПК Path_Length: 151 2014/5/28:03:21:37 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI67B0.tmp 2014/5/28:03:21:37 User USER-ПК Launch 2014/5/28:03:21:38 User USER-ПК PageOpen LaunchDialog 2014/5/28:03:21:44 User USER-ПК === Setup ended === 2014/5/28:03:21:52 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:03:21:52 User USER-ПК Path_Length: 151 2014/5/28:03:21:52 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm 2014/5/28:03:21:52 User USER-ПК Launch 2014/5/28:03:21:52 User USER-ПК CommandLine 2014/5/28:03:21:52 User USER-ПК Path_Length: 151 2014/5/28:03:21:52 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIAAF7.tmp 2014/5/28:03:21:58 User USER-ПК === Setup ended === 2014/5/28:03:21:54 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:03:21:54 User USER-ПК Path_Length: 151 2014/5/28:03:21:54 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIAAF7.tmp 2014/5/28:03:21:54 User USER-ПК Launch 2014/5/28:03:21:58 User USER-ПК PageOpen LaunchDialog 2014/5/28:03:23:03 User USER-ПК PageOpen LicenseDialog 2014/5/28:03:23:06 User USER-ПК PageOpen ProductInfoDialog 2014/5/28:03:23:30 User USER-ПК PageOpen ProductSelectionDialog2 2014/5/28:03:23:32 User USER-ПК PageOpen FullProgressDialog 2014/5/28:03:23:32 User USER-ПК Installing DirectX® Runtime: "C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/5/28:03:26:11 User USER-ПК Install DirectX® Runtime Succeeded 2014/5/28:03:26:11 User USER-ПК Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:03:26:27 User USER-ПК Install Autodesk® Material Library 2014 Succeeded 2014/5/28:03:26:27 User USER-ПК Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:03:26:40 User USER-ПК Install Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/28:03:26:41 User USER-ПК Installing Autodesk® Material Library 2014 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:03:28:13 User USER-ПК Install Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/28:03:28:14 User USER-ПК Installing Autodesk® 3ds Max 2014: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AIAAF7.tmp\x64\max\3dsMax2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:03:28:41 User USER-ПК Install Autodesk® 3ds Max 2014 Failed Installation aborted, Result=1603 2014/5/28:03:28:53 User USER-ПК Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/28:03:29:04 User USER-ПК Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/28:03:29:24 User USER-ПК Rollback Autodesk® Material Library 2014 Succeeded 2014/5/28:03:29:24 User USER-ПК Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/5/28:03:29:24 User USER-ПК PageOpen InstallCompleteDialog 2014/5/28:03:30:08 User USER-ПК === Setup ended === 2014/5/28:03:33:41 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:03:33:41 User USER-ПК Path_Length: 151 2014/5/28:03:33:41 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI775A.tmp 2014/5/28:03:33:41 User USER-ПК Launch 2014/5/28:03:33:44 User USER-ПК PageOpen LaunchDialog 2014/5/28:03:33:50 User USER-ПК === Setup ended === 2014/5/28:03:33:40 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:03:33:40 User USER-ПК Path_Length: 151 2014/5/28:03:33:40 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm 2014/5/28:03:33:40 User USER-ПК Launch 2014/5/28:03:33:40 User USER-ПК CommandLine 2014/5/28:03:33:40 User USER-ПК Path_Length: 151 2014/5/28:03:33:40 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI775A.tmp 2014/5/28:03:33:52 User USER-ПК === Setup ended === 2014/5/28:03:33:53 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:03:33:53 User USER-ПК Path_Length: 151 2014/5/28:03:33:53 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm 2014/5/28:03:33:53 User USER-ПК Launch 2014/5/28:03:33:53 User USER-ПК CommandLine 2014/5/28:03:33:53 User USER-ПК Path_Length: 151 2014/5/28:03:33:53 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIA839.tmp 2014/5/28:03:33:55 User USER-ПК === Setup ended === 2014/5/28:03:33:53 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:03:33:53 User USER-ПК Path_Length: 151 2014/5/28:03:33:53 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AIA839.tmp 2014/5/28:03:33:53 User USER-ПК Launch 2014/5/28:03:33:54 User USER-ПК PageOpen LaunchDialog 2014/5/28:03:33:56 User USER-ПК PageOpen LicenseDialog 2014/5/28:03:33:59 User USER-ПК PageOpen ProductInfoDialog 2014/5/28:03:34:34 User USER-ПК PageOpen ProductSelectionDialog2 2014/5/28:03:34:53 User USER-ПК PageOpen FullProgressDialog 2014/5/28:03:34:53 User USER-ПК Installing DirectX® Runtime: "C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/5/28:03:36:57 User USER-ПК Install DirectX® Runtime Succeeded 2014/5/28:03:36:57 User USER-ПК Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:03:37:07 User USER-ПК Install Autodesk® Material Library 2014 Succeeded 2014/5/28:03:37:07 User USER-ПК Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:03:37:30 User USER-ПК Install Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/28:03:37:30 User USER-ПК Installing Autodesk® Material Library 2014 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:03:39:07 User USER-ПК Install Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/28:03:39:08 User USER-ПК Installing Autodesk® 3ds Max 2014: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AIA839.tmp\x64\max\3dsMax2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" INSTALLDIR="C:\Program Filesq\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:03:39:31 User USER-ПК Install Autodesk® 3ds Max 2014 Failed Installation aborted, Result=1603 2014/5/28:03:39:44 User USER-ПК Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/28:03:39:54 User USER-ПК Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/28:03:40:15 User USER-ПК Rollback Autodesk® Material Library 2014 Succeeded 2014/5/28:03:40:16 User USER-ПК Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/5/28:03:40:19 User USER-ПК PageOpen InstallCompleteDialog 2014/5/28:03:40:26 User USER-ПК === Setup ended === 2014/5/28:15:05:49 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:15:05:49 User USER-ПК Path_Length: 151 2014/5/28:15:05:49 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm 2014/5/28:15:05:49 User USER-ПК Launch 2014/5/28:15:05:49 User USER-ПК CommandLine 2014/5/28:15:05:49 User USER-ПК Path_Length: 151 2014/5/28:15:05:49 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI2542.tmp 2014/5/28:15:05:59 User USER-ПК === Setup ended === 2014/5/28:15:05:52 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:15:05:52 User USER-ПК Path_Length: 151 2014/5/28:15:05:52 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI2542.tmp 2014/5/28:15:05:52 User USER-ПК Launch 2014/5/28:15:05:56 User USER-ПК PageOpen LaunchDialog 2014/5/28:15:05:57 User USER-ПК PageOpen LicenseDialog 2014/5/28:15:05:59 User USER-ПК PageOpen ProductInfoDialog 2014/5/28:15:06:48 User USER-ПК PageOpen ProductSelectionDialog2 2014/5/28:15:06:49 User USER-ПК PageOpen FullProgressDialog 2014/5/28:15:06:49 User USER-ПК Installing DirectX® Runtime: "C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/5/28:15:09:02 User USER-ПК Install DirectX® Runtime Succeeded 2014/5/28:15:09:02 User USER-ПК Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:15:09:32 User USER-ПК Install Autodesk® Material Library 2014 Succeeded 2014/5/28:15:09:32 User USER-ПК Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:15:09:42 User USER-ПК Install Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/28:15:09:42 User USER-ПК Installing Autodesk® Material Library 2014 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:15:11:06 User USER-ПК Install Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/28:15:11:07 User USER-ПК Installing Autodesk® 3ds Max 2014: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AI2542.tmp\x64\max\3dsMax2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:15:11:43 User USER-ПК Install Autodesk® 3ds Max 2014 Failed Installation aborted, Result=1603 2014/5/28:15:12:00 User USER-ПК Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/28:15:12:16 User USER-ПК Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/28:15:12:36 User USER-ПК Rollback Autodesk® Material Library 2014 Succeeded 2014/5/28:15:12:37 User USER-ПК Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2014/5/28:15:12:38 User USER-ПК PageOpen InstallCompleteDialog 2014/5/28:15:12:56 User USER-ПК === Setup ended === 2014/5/28:15:44:30 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:15:44:30 User USER-ПК Path_Length: 151 2014/5/28:15:44:30 User USER-ПК Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm 2014/5/28:15:44:30 User USER-ПК Launch 2014/5/28:15:44:30 User USER-ПК CommandLine 2014/5/28:15:44:30 User USER-ПК Path_Length: 151 2014/5/28:15:44:30 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI8F79.tmp 2014/5/28:15:44:40 User USER-ПК === Setup ended === 2014/5/28:15:44:31 User USER-ПК === Setup started on USER-ПК by User === 2014/5/28:15:44:31 User USER-ПК Path_Length: 151 2014/5/28:15:44:31 User USER-ПК Current Directory C:\Users\User\AppData\Local\Temp\_AI8F79.tmp 2014/5/28:15:44:31 User USER-ПК Launch 2014/5/28:15:44:37 User USER-ПК PageOpen LaunchDialog 2014/5/28:15:44:44 User USER-ПК PageOpen LicenseDialog 2014/5/28:15:44:46 User USER-ПК PageOpen ProductInfoDialog 2014/5/28:15:45:16 User USER-ПК PageOpen ProductSelectionDialog2 2014/5/28:15:45:21 User USER-ПК PageOpen FullProgressDialog 2014/5/28:15:45:21 User USER-ПК Installing DirectX® Runtime: "C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent 2014/5/28:15:46:57 User USER-ПК Install DirectX® Runtime Succeeded 2014/5/28:15:46:57 User USER-ПК Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:15:47:08 User USER-ПК Install Autodesk® Material Library 2014 Succeeded 2014/5/28:15:47:08 User USER-ПК Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:15:47:31 User USER-ПК Install Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/28:15:47:31 User USER-ПК Installing Autodesk® Material Library 2014 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:15:48:28 User USER-ПК Install Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/28:15:48:30 User USER-ПК Installing Autodesk® 3ds Max 2014: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AI8F79.tmp\x64\max\3dsMax2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2014/5/28:15:48:54 User USER-ПК Install Autodesk® 3ds Max 2014 Failed Installation aborted, Result=1603 2014/5/28:15:49:09 User USER-ПК Rollback Autodesk® Material Library 2014 - Medium Resolution Library Succeeded 2014/5/28:15:49:17 User USER-ПК Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded 2014/5/28:15:49:33 User USER-ПК Rollback Autodesk® Material Library 2014 Succeeded 2014/5/28:15:49:33 User USER-ПК Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
100500 раз создавали подобные темы, посмотрите почитайте осознайте ))) и лог можно было бы просто тексовым фаслом во вложении сделать )))
Andrey Plaksin CG Artist
portfolio
Facebook |Personal project
Находите сообщения полезными? Поставьте Нравится (Like) этим сообщениям!
На ваш вопрос успешно ответили? Нажмите кнопку 'Утвердить решение'
Не нашли то, что искали? Задайте вопросы в сообществе или поделитесь своими знаниями.
