Hi Area.
Looking for solution to make my commands from python undoable.
At moment in 2016 SP3 python commands are not undoable. Executing maxscript code from python stack also does not add any undo entry.
There is idea to make timer that will look in to global variable filled with values from python. Will post here result if succesful.
Solved by kostyamaslyuk. Go to Solution.
Yes, introducing MaxScript facility for delayed execution of maxscript commands, constructed from Python stack works, undo entry appears in undo stack. Solved.
