Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Protecting Maxscript
MehdiZangenehBar
Message 1 of 20
MehdiZangenehBar
Maxscript encryption or dll are not safe, How we can protect maxscript by using SDK?
Replies (19)
Message 2 of 20
paulneale
You can't, everything can be cracked. Autodesk spends millions I'm sure on licensing and it isn't 100% secure. Problem is you can spend more time and money trying to protect your tools then you would loose in loses if you just didn't bother.
Paul Neale
http://paulneale.com
Paul Neale
Message 3 of 20
MehdiZangenehBar
So, How we can make plugins commercial?
Message 4 of 20
paulneale
Encrypt the Max script if you want to sell it and create a simple licensing system or just sell it. If it is a huge success it will be cracked, there is no way around that. But companies and people that are not theifs will purchase it.
Paul Neale
Paul Neale
Message 5 of 20
I've found a great plug-in for maxscript protection. It can be helpfull: http://www.scriptspot.com/3ds-max/scripts/maxscript-protector
Mse is not the only way of encryption.
Message 6 of 20
Sorry, the link was broken. The correct link to plug-in: http://www.turbosquid.com/FullPreview/Index.cfm/ID/1089390?referral=crea3d
Message 7 of 20
kevinvandecar
Yes, I agree with the others here. MAXScript is a scripting language, so in itself it is not possible to perfectly encrypt it.
To answer the commercial question, if you really want the best security, use the C++ SDK. It produces a native DLL that is very hard to crack. This is what many commercial developers do with at least the core functionality. Also remember that a C++ plugin can expose it's functionality to MAXScript and so you might consider just moving your most important IP into a C++ plugin, and then call it from some of your less critical MAXScript code.
As Paul mentioned nothing is 100% secure, but in C++ it is as close as you can get, and it takes deep understanding of binary and assembly code to crack a native DLL. So your best option is to put your important IP there, and then nothing "extra" is needed for encryption. Of course C++ itself can be much harder to code in, so it's a trade off (but you may also gain some performance, depending on what you are doing...). 🙂
Hope it helps,
kevin
Kevin Vandecar
Developer Technical Services
Autodesk Developer Network
Message 8 of 20
MehdiZangenehBar
I just created this topic two years ago , but useful Thank You!. although I'm not a professional C++ programmer, but C++ works very well in this situation. After thinking about the protecting concepts, I realized (as paul said) that spending a lot of time on protecting the MaxScript is not a good idea and I must focus on coding, promote and support.
Message 9 of 20
The only solution I know for now for those who write in maxscript is this plugin.
Message 10 of 20
denisT.MaxDoctor
Using this solution, you lose the opportunity to use your customers as free testers, which for real developers saves a lot of time and money.
Message 11 of 20
istan
I don't use this protection but why would I loose my customers for beta testing? I'm sure one can create a beta testing time by using e.g. crazy registry access for creating many weird keys which makes it almost impossible to be narrowed down, for the case someone uses procmon.
Message 12 of 20
MehdiZangenehBar
Denis, I'm so happy that I see you in this forum also, I really appreciate it.
I didn't get your point, why we loose them?
Message 13 of 20
denisT.MaxDoctor
the encryption tool with the link above is nothing more than an obfuscater.
it screws all original lines of code and property and function names. in case if this "encrypted" code crashes you will not get any clue where it was happened.
you will get from your client just a message - "your code crashes" and maybe sad smiley at the end
how to debug it?
Message 14 of 20
denisT.MaxDoctor
don't buy this tool!
it's a fake! it doesn't work
Message 15 of 20
Other not perfect solution is to write certain parts of your code in c# if you don't want to get deep into the C++ SDK. It's also not a perfect solution, you have to use a defuscator here as well, but it's still safer than the maxscript version. Also maxscript can be simply decrypted using free tools over the internet.
C# is a bit harder to decrypt, but not as complicated as learning c++. Also the c# version is version independent in many cases, so you don't have to ship per version dlls. And of course it's much faster than the maxscript version.
I realized over the years that using maxscript is getting more and more old school, you have to do a lot of workarounds to make things work, as well as there are many cases where there are very nasty memory leaks. It's worth the time to learn c# and the max sdk.
Message 16 of 20
nigel.hunt
I've read this thread and thought I'd jump in.
If you really have a great Maxscript you want to protect, it needs to be rewritten in C++ and compiled as a plugin.
SiNi Software offers a custom service to write this...
https://www.sinisoftware.net/index.php?option=com_content&view=article&id=36&Itemid=526
SiNi have 11 plugins and over 150 tools for 3ds Max 2014-2018. The tools started out as Maxscript and were rewritten in C++ (over 3 million lines of code in 2 years!). The plugins are tied to a licence server for extra security.
The developers also writes bespoke Maxscript for some of the largest companies in the world using 3ds Max.
For public release, C++ is your only choice.
Nigel
Message 17 of 20
denisT.MaxDoctor, It's absolutely not a fake. If you have this plugin, update to version 2.1.2. Some issues solved there, now everything works fine in all 3Ds max versions.
Message 18 of 20
miauuuu
Can you show any example - ms file and protected file using Maxscript Protector?
https://miauu-maxscript.com/
Message 19 of 20
miauuuu
Copy - paste from scriptspot.com about Maxscript Protector:
Originally Posted by Submitted by 3DZver on Mon, 2018-01-29 16:06.: Submitted by 3DZver on Mon, 2018-01-29 16:06.
Maxscript Protector absolutely non-working toolI read a lot about Maxscript Protector. Basically bad reviews, and if there were praise comments - then these comments post the developers
themselves. I did not regret money and purchase this script specifically
to check how it works. None of the scripts I tried to protect with this
tool, and did not work after that. I wrote to the authors of this
script and reported on, but they did not even bother to answer.
My verdict: Maxscript Protector absolutely non-working tool and I do not advise anyone to buy it.
Message 20 of 20
MehdiZangenehBar
If we want to use external protector, I think this is not only about MaxScript, Actually we need a more general and stronger protector that works also for all other software packages. The main goal for me to protect MaxScript is not just my source code (Actually I can share it online if someone ask me!). but managing registrations become important (because I earned money from customers). So I think a C++ and exposing some necessary MS inside it should be enough.
